Ohio Billet crankshaft for a bbc
Results 1 to 14 of 23
    Senior Member blownsouthwind's Avatar
    surprise,AZ
    Default Ohio Billet crankshaft for a bbc
    in need of a new crank. Would this crank be a good choice for Blown Alcolhol in a jet boat B44544000. seems like a good price.
    waterloo
    This is going to get real good, real fast.
    Wags
    Default crank
    GN7 will be by here real soon and i will imagine procomp will get discussed again i will bet he is going to tell you that ohio cranks are a bunch of Chinese cranks that look like they were pulled out of a hobbos ass.
    Default ohio cranks
    I looked at some of the other forums seams like alot of people are having good luck with them a few have had some with tapered journals but i think they are like eagle or scat they get the material overseas and do all the machining there. Whats a little funny to me though is on there website they are all about ohio stuff but are selling bill miller rods and a few other different company's parts.
    Tower Park Resort, Lodi, CA
    Wags
    X2
    Default crankshafts
    Or are they worse than eagle or scat i think im just going to shut my mouth and sit back and listen
    You get what you pay for.
    Mar 2010
    Clarksville, TN
    Ask Mailman what he thought about his Ohio Crankshaft!!! I will admit it took one hell of a beating before it broke
    Kinda depends on what you mean by "blown alcohol". If your talking a low compression/boost application where you're making less than 1000 HP, I've seen guys get chevy steel cranks to live in blown alky applications. If you're running higher compression, good heads, a bunch of boost and leaning on the tune up, I'd put a better crank than an Ohio in it. Just depends on what you're doing and how lucky you feel....
    Quote Originally Posted by matt wheeler View Post
    GN7 will be by here real soon and i will imagine procomp will get discussed again i will bet he is going to tell you that ohio cranks are a bunch of Chinese cranks that look like they were pulled out of a hobbos assI guess .
    I guess because they are called "Ohio Crankshaft" they must be forged here.
    When did that start applying it anything. specially crankshafts?
    I won't let on in the garage for fear it might accidently end up in an engine. Same thought process as a bad bolt or nut. Beat it beyond recognition and throw it in the round file.
    For about 750.00(cheaper if you hunt) you can buy a Lunati Sledgehammer. Thats not enough money to make me put a Ohio POS in my engine.
    For less than 700.00 you can buy a Callies Compstar. Now thats almost a no brainer.
    If your running stock length rods forget both of them. But then ask yourself why on that too.
    Bigger question is why you are running a 4.00 crank in a blown alky deal?
    Gone
    Sparks, Nevada
    "I'd put a better crank than an Ohio in it."
    Yep.
    Best crank you can afford for blown alcohol regardless. I'm thinking Callies or better.
    Kent, WA
    Why not ? Just curious what your thoughts are on a "better" stroke ?
    Are all the Ohio stuff not good ?
    Not a matter of just stroke. I am a big fan if CID for free. If you're buying a crank or a rotator, why not go for the extra cubes. I like 4.25 blown deals. I like making power in a big block without having to spin it like a SBC. I now, we spin them like SBCs and it SUCKS.
    Senior Member 18GullwingMailman's Avatar
    Dec 2010
    Conway, AR
    Default Stay away from Ohio Cranks
    Stay away from the Ohio cranks unless you wanna spend money for... And this is me...I got lucky and didn't bend a rod...Or smack a valve with a piston or hurt a lifter or the cam.
    new crank
    main bearings
    rod bearings
    pistons (hey I only needed 4 - but splurged and got 8)
    piston rings
    gaskets (don't think a full set is cheap)
    All the above was 5500.00
    This was NOT a billet crank, but it's replacement was.
    Buyer beware as they say...
