How do I grease this zirk .....
Results 1 to 8 of 8
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    Default How do I grease this zirk .....
    There's not enough room for the grease gun end to fit .... is there a special tip for a grease gun?
    Senior Member HypNautic's Avatar
    20 min from Mead, 1 1/2 hours from Mohave, 2 hours from Havasu
    There is a needle fitting you need. Fits to the end of your gun and the tip will push in the zerk.
    Sent from my SPH-D710 using Tapatalk 2
    Quote Originally Posted by Franger View Post
    I'd be tempted to take a die grinder to that and fix the problem.
    Aug 2011
    Wasilla, Alaska
    Quote Originally Posted by HypNautic View Post
    thanks, I'll check at Napa tomorrow
    Aug 2011
    Wasilla, Alaska
    I was thinking the same thing but thought I'd check in here first ... thanks Bob
    Redding, CA
    Needle tip for gun.
    Or try putting a 45* zerk in it, might not have room to screw it in though.
    New Jersey
    How about a grease fitting extension.
    GREASE FITTING EXTENSION, GREASE FITTING ADAPTERS, PLUGS, BUSHINGS
    Doug
    Aug 2011
    Wasilla, Alaska
    Quote Originally Posted by Real McCoy View Post
    Cool, hadn't thought about an extension, thanks
