Spark plugs for Aluminum heads?
Results 1 to 7 of 7
    Jan 2010
    So Cal
    Default Spark plugs for Aluminum heads?
    516ci BBC, N/A
    8.75:1 Comp
    AFR 305 heads, CNC chambers
    Dart intake, 830HP carb
    Hyd roller, 228/235 @.050, 650/603
    5500 rpm max
    Lake boat with a Bravo drive.
    AFR says Autolite AP3935 or AP3932,
    NGK cross reference's with the 3932 as a 10 heat range... cold??
    the 3935 Cross references with a 7 heat range, closer to the BR6FS's I ran with the Iron headed motor.... Not sure where to start Shouldn't I be using a resistor plug??
    El Cajon, Ca.
    Quote Originally Posted by 28Eliminator View Post
    516ci BBC, N/A
    8.75:1 Comp
    5500 rpm max
    NGK 4554 is a good place to start... may be a bit cold being a 8 heat range. Actually, 4091 would be the 7 heat range and may be more of what you'd need.
    The Bostick®
    516ci BBC, N/A
    8.75:1 Comp
    5500 rpm max
    I'm thinking the 32 is way too cold.
    The 35 is better of the two.
    Canfield always recommended a 3924 as a starting point...even a little warmer yet (NGK 5) and it always seemd OK. I like to run as hot a plug as possible and still have it live and do it's job.
    Senior Member Futs's Avatar
    Orange CA, Big River
    Will to cold of a plug make it run alittle rich throughout the throttle or just at idle or WFO or any at all??
    I use some 3923 Autolites, couple steps colder than the stock 25, with no reported problems. I use them since they are readily available at parts stores, but I would run non resistor plugs if they were easier to get. Engine I just had on the dyno had NGK-7's, more compression and higher rpm than you are working with.
    Jan 2010
    So Cal
    NGK 4554 is a good place to start... may be a bit cold being a 8 heat range. 4091 would be the 7 heat range.
    The 4091 is the R5671A-7, which cross references with the 3935...
    Another vote for the 3935's... I'll start with them.
    3923's are resistor plugs?? Is there a particular reason for running the resistor? I though it was just the radio thing... what about the type of ignition system?
    sorry, it's my first set of Aluminum heads
    Mar 2010
    Clarksville, TN
    I call NGK tech support when I don't know and that boy damn near nails it everytime. Not sure his name but the same guy has always answered the phone.
