Engine Crank Stroke???
Results 1 to 14 of 38
    Member Mach80's Avatar
    Phoenix, Az
    Default Engine Crank Stroke???
    I'm trying to determine what stroke crank is in my boat. Does anyone have a way to measure stroke or Cubic inches without removing a head? The engine is installed in the boat but I'm not sure if it is a 509 or a 540.
    Thanks.
    Senior Member 2002CP19's Avatar
    Lake Arrowhead/Lost Lake
    Quote Originally Posted by Mach80 View Post
    Thanks.
    use something like a pencil. Take out the plug. Rotate to BDC, locate an index point (top of threads) make a mark. Rotate to TDC make another mark and measure. Stroke x bore x 8=CID
    Senior Member Flat BROKE 612's Avatar
    Feb 2010
    Bumblefvck PEI
    Quote Originally Posted by 2002CP19 View Post
    1/2bore x 1/2 bore x pi x stroke x #cyls
    Quote Originally Posted by Flat BROKE 612 View Post
    bore X bore X .7854 X Stroke X #cylinders
    So, you have a magic pencil that can make the turn and drop straight down the cylinder for this high tech method?
    Why did people spend 1500.00 plus for a CID tester when you can do it with a pencil?
    stock 454 bore/stroke
    4.00(stroke) X 4.250(bore) X 8= 136
    I what you checking my engine size at the races
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    Bob, Wouldn't the correct tool for a mechanic to use in this procedure be a ....... "mechanical" pencil?
    I didnt say it was high tech. Just a thought...
    I've been wrong before.
    OH, I thought you had personal experience with that method
    Quote Originally Posted by Franger View Post
    I perfer to use a Camodian Magic Wand myself.
    Feb 2010
    Bumblefvck PEI
    Ya but mine has PI!!! MMMMM pie.......
    Nov 2009
    Jerome, Idaho
    Find someone who has a P&G that can pump the motor for cubic inches.........like at a sanctioned race or some who may be involved with such things!!!!!!
    Well I have used that method before, just not to measure.
    Looks like the cambodian unit will do the trick...
    Senior Member bp298's Avatar
    LHC
    only if it's a "union" mechanic.
    radius (1/2 bore diameter) squared x 3.1415927 x height(stroke) x 8
    or, pi x r2 x stroke x 8
    with a p&g meter, if you get really really lucky, somebody might get within 10% of the actual ci with it. POS...
    You guys sure do like you PI. MMMMMmmmmmmm pie!
    Nov 2008
    Orangevale CA
    Pie is always Good , Bob ,,, Apple , Berry , Peach , Cherry , HAIR , (lol) ....... MMMMMMMMMMM PIE ...
