Cavitation rod leaking at hose
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    Default Cavitation rod leaking at hose
    Does anyone know who makes this thru hull hardware? With the hose clamp as tight as I can get it the blasted thing still leaks and the hose looks to be brand new. Seems to me I remember a thread showing half moon shaped pieces that went on the outside of the hose to help the hose clamp put pressure on the sides to create a good seal?
    Anyone have any good ideas how to improve this.....
ID:	163559   Click image for larger version.
    Franger, never seen that EXACT setup, but I think there is something missing there. The outside piece is suppose to be screwed to a matching piece inside. Not to the hull. If you go to page 68 in this catalog (sorry its a PDF and I am not smart enough to convert it) will see what it should look like.
    LINK: glenwood catalog
    Aug 2011
    Wasilla, Alaska
    Looks like what REX sells neither of which look like what I have on the outside of the transom
    Quote Originally Posted by Franger View Post
    IT IS what Rex sells.
    I only posted it to let you know what you have is incomplete. There should be an inboard part to that regardless who made it.
