Spark plug help
Results 1 to 5 of 5
Spark plug help
    Senior Member namba860's Avatar
    Las Vegas, Nevada
    Default Spark plug help
    I have a carbureted mild 502 with aluminum heads and dont know if i have the correct plugs in it. Im not sure whos cylinder heads they are. The plug that came out of it was an ngk vpower 8 they are a long reach with a crush washer on them. Any recomendations?
    Jun 2010
    Autolite 3924
    Quote Originally Posted by namba860 View Post
    Thats about right. If the compresion is pump gas range you might try a 7. But almost all the aftermarket late alum heads use the .750 reach gasket plug.
    Quote Originally Posted by mdsheppie View Post
    Autolite 3924
    Even Ford lovers don't run Autolites anymore.
    Jun 2010
    okay I shut up now,sorry
    El Cajon, Ca.
    Good spark plug... depending on combo may be a little cold... but a good refrence point. The stock number on what you have is 4554 (p/n R5671A-8) and is a fairly common starting point plug number. See what the engine likes... if it appears you need a warmer plug... go with a #7. Nice thing about the NGK plugs are they are fairly easy to read.
    The Bostick®
