powder coat or ceramic coat?
Results 1 to 9 of 9
    Senior Member MR.Magoo's Avatar
    Default powder coat or ceramic coat?
    not sure on header coatings can you run powder coat on headers? or do they need to be ceramic coated? i'm tired of polishing
    ceramic .... powder coat can't take the heat.
    where are you located?
    Jon
    Jul 2010
    Lubbock, TX
    There are some high-temp powder coatings that can take up to 1200 degrees. They are usually black, a silver color, and a titanium gray. But...I still vote ceramic.
    At least I think those high-temp coatings aren't ceramic based.........
    "No, my boat doesn't need any more power" - No one ever
    Senior Member md-11mike's Avatar
    May 2012
    Thousand Oaks Ca
    X3 ceranic
    Oct 2011
    No powder coat can handle it. Maybe on logs but not headers. Ceramic coat them and be done with polishing forever
    Coeur d'Alene, Idaho
    Quote Originally Posted by rpm0414 View Post
    Who ceramic coated your exhaust...
    Oct 2011
    I had done up here in Portland by finish line coatings.
    Diamond Bar, Big River
    Post
    aren't you in texas? If I'm not mistaken Jett Hot is there in texaz no? Their one of the best ceramic coaters in the nation. lookem up, get'em coated and enjoy. If you run them dry you may have to occasionally hand polish them from the flange out 3" or so if you want to maintain that new shine but that just anal perf. preference. Good luck with whatever you choose.
    yep i'm in texas, i didnt know jet hot was in texas, i heard of wolfe's coatings they are in la porte which is near houston, about 120 miles from me.
