Hey GN7...which plugs
Results 1 to 14 of 20
    Arroyo Grande
    Default Hey GN7...which plugs
    So Bob, Scott and I were discussing which spark plug to run....
    Prefer the NGK's....what heat range????
    let the debate began.....
    before you ask..it's for the 588
    Senior Member bp298's Avatar
    LHC
    gn's off on a play date. you'll have to wait awhile...
    Arroyo Grande
    Take a shot at it. Let's hear your guess
    Mar 2010
    Clarksville, TN
    What compression and fuel you running???? Might help
    NGKs, period.
    I like 8s. some like to tune with 7s and run 8s. I toss a 9 in the thing and the readings seem to go to hell. The 7 do seem easier to read, but the 8s are easy enough for me.
    I agree with Steel on plug heat ranges though. The hottest plug you don't burn up. I have run 7s in a race at Puddingstone and the side electrode drooped alittle from heat. The gap was about .125 bt the end of the race. Puddingstone is a little unusual in the thing is WOT for 20 laps. We could probably get away with 7 at most courses, but I just buy 8s and it makes it easier.
    The hotter the better.
    My next choice is Autolites, but I can't seem to read anything but mixture on them. Others swear by them.
    Yes, bp298 is right, we are on a "hot date" but nothing too exciting goinmg on yet.
    El Cajon, Ca.
    NGKs, period.
    x2
    I like to start with 8's and then go from there... but on the bottle I start with 9's then go from there. Something about having a little bit of safety margin to start off seems real apealing.
    The Bostick®
    Arroyo Grande
    Pump gas deal. This is for my 26 Daytona. Comp is about 8 to 1
    You may very well be able to run 7 in that easily. I am not a big fan if running "cold" plugs. The plug will let you know its too hot. I think I would consider 7s as a intial start. That things big and you aren't going to be spinning it like a SBC. Your sure as hell don't need a plug that gives up when your cruising the channel, or trying to dock that beast.
    Jan 2011
    Mickleton, New Jersey
    9 in race boats (alky) and 7 in pleasure boat and 6 in stock boats ( BR6FS ) I would run a 6 in that one NGK even have 10/10.5/11 heat ranges by far the best
    Quote Originally Posted by jimclauss View Post
    Uh Jim, it may have 8 to 1 compression, but it does have a 14-71 blower sitting on it with a fairly decent roller cam and you just recommended a a plug you recommend for a "stocker" Just sayin
    Jan 2011
    missed that( where did he say that? ) go with the 8 or 9 Now much boost?
    He neglected to include that "little detail".
    It's a 588, 1471, 9-10# boost, hopefully in the 1100hp range. Max rpm 6500.
    I think the 7 is a good place ot start. May be a little warm...if he's going to poker run this thing, we can stick some 8's in it.
    Senior Member racinjason65's Avatar
    May 2011
    Huntington Beach
    Hopefully he makes the Monster Bash Poker Run! I'd like to see this motor run!
    That would be my approach.
