Buzz timing.
Results 1 to 7 of 7
Buzz timing.
    Cantard 71hallett's Avatar
    snow bank
    Default Buzz timing.
    Bought a Malory sprint super mag III and it says to set the buzz timing using the yellow wire. Someone explain this to me please. Never used a mag and dont want to fk it up.
    Paul
    snow bank
    Looks like I need a buzz box unless there is another way.
    92 KURTIS RUNNER BOTTOM
    Hey Paul Ol Guy will know he knows everything, send him a PM
    A ARMED SOCIETY MAKES FOR A MORE CIVIL SOCIETY
    Paul looking at your avatar I noticed something wrong with the motor, the small pulley goes on top and big on the bottom
    Quote Originally Posted by BAD REACTION View Post
    Hey B.A.,thanks for the thought but If I ever get to knowing everything just shoot me because the fun of learning is the reason for life. PAUL< no you don't need a buzz box. You can actually do it with a continiuty tester. Think of points and when they open you lose the ground and the light goes off. Set motor up at tdc then retard 1/16 turn,hook light pigtail to positive on the battery and prob to wire connection on mag light should be on. Then set motor for what you want for total and turn mag till you lose ground and light goes off, thats assuming you are using a locked down distributor. (points open sending charge to plug) Strap the distributor down and go. Mark
    Default Timing lights
    Based on performance timing, you can use a timing light. The only thing you are doing is changing from a "Known" number. If you're running 35 locked out, according to a timing light, and you want to add a couple of degrees, use the same light, and get your 2 degrees. It is all about base lines and varibles from there. I've used a light on a Zig Vertex for years. (If you want to do it as directed above, just look up an old VW beatle, same deal)........I would suggest a "dial back" light however, it is easier to set to zero on the balancer. Another point here is "absolute TDC".......Unless it was established with, and correctly marked, using a degree wheel, it is a crap shoot trying to be dead on within 2 or 3 degrees..........MP
    LOUD BOATS SAVE LIVES
    snow bank
    Thanks Guys.
