EFI Hat Question
Results 1 to 10 of 10
EFI Hat Question
    Senior Member Big Otis's Avatar
    Default EFI Hat Question
    Does anyone run one of these?
    Can you realy tune it with a Laptop/Ipad?
    I know the Carb's are fine, But a Hat just look's Bad A$$.
    I had Injected gas Tunel-ram deal, It was to much for my dumb-a$$ to tune.
    Quote Originally Posted by Big Otis View Post
    You thinking of that on a t ram base, or a blower?
    Chico, Ca
    On most efi hat setups I've seen they block off the two outer butterflies so the center is the only one that flows air. This makes it much easier to tune and much more predictable. Really helps you take advantage of electronic fuel injection and the benefits it offers over carbs and mechanical such as mid range, fuel efficiency, cruise, idle...things like that.
    Andrew
    Probably going to run on a blower motor.
    So you don't have to run pills or check the temperature, altitude or anything?
    There is one small issue with that type of setup. Airflow thru the butterflies is anything but linear. Its down right terrible. Like AP said, they usually block the two outer butterflies to help, but its a band aid at best.
    EFI is 100% dependent on perdictable air flow or a least a mass air measureing device. Trying to map a speed density or Alpha-N system with a hat is not a amatuer undertaking.
    This boat is working out a EFI and hat deal. Its not easy and they have one of the best in the business working on the system. It has custom built butterflies that help make the airflow much more linear. They aren't blades like a normal hat. They are more like the center cross section of a ball. The blades are thick and the sides are curved.
    Its not working all that great right now. They will get it, and it will work. But its not a simple thing to work thru. Specially if you think a MFI is tuff. MFI is a walk in the park compared to working thru a deal like this.
    Kent, WA
    I loaned my spare "modified" hat to Richard to try on a new boat. It has the modified butterflies. Call him and chat with him about it !
    What new boat?
    Kent, WA
    I'm not sure, Richard just told me that he was doing the engine for a new K boat ???????
    Senior Member TurboNova's Avatar
    Dec 2009
    Lake Havasu City AZ
    Part of the issue with the pictured setup, is not having enough injector. The current setup I am working on is a hat like this but only has 4 injectors and even with 4 - 160s it is not enough. So make sure you have at least enough fuel for your combo. I would even make the injectors larger than you think you need for a blown setup. I have tuned many of these with EFI and they are not a walk in the park but can work just fine if you know what you are doing. Alpha N has no place in tuning something like this.
    From what I found dyno testing most engines become more driveable by blocking at least one butterfly. Most of the engines lost a little power by blocking the second butterfly.
    I have also used Robs "Rootz EFI" plate and it not only looks nice but works well too.
    Jul 2012
    thanks for the plug brian its always a pleasure working with you... see you at monster bash!
    Home -
