ignition timing BBC
Results 1 to 14 of 28
ignition timing BBC
    Senior Member 69 wriedt devil's Avatar
    Aug 2011
    central Cali
    Default ignition timing BBC
    was wondering if someone can steer me in the right direction. I have a blown BBc 427 with 2 750 holley carbs. the boat runs great for the most part. Now every now and again when i jump on the throttle, there is a nano second of a hesitation. fuel pressure set at 7. what should my timing be ballpark? since ive had the boat, never checked timing because the boat ran so good. thx
    Aug 2011
    central Cali
    oh yeah, i removed my headers and installed zoomies. didnt like the zoomies so i re-installed headers, not sure if that makes a difference.
    Tower Park Resort, Lodi, CA
    The guys who will be able to help will want to know your compression ratio, how much boost you're making, and what fuel you use. Might also want to know aluminum or iron cylinder heads, distributor, and if it's locked.
    Aug 2011
    central Cali
    great, dont have a boost guage, not sure about compression, thats what sucks when you buy an engine and the guy you bought it from doesnt know anything. i am running 100LL av gas, and mallory distributor with pertronix no points. thx
    Aug 2011
    central Cali
    All the info i have
    Mfi
    Locked distributor
    Iron heads
    Twin 750 holleys.
    100ll av gas
    Gonna buy a boost guage, but will not know compression ratio
    Idles at 1100
    What is your timing set at now?
    I have next to zero experience with blower engines, so I'm not the guy to send you in the right direction... just making it easier to get the answer you're after.
    In my experience, a slight hesitation off idle would be a carb setting issue. Accelerator pump, accelerator pump cam, transition circuit... something like that. But, who knows...
    Oh! What blower? 8-71??? Over/under drive ratio?
    Douglas, MA
    The first place I have always been told to look was the accelerator pump
    Aug 2011
    central Cali
    Ok. Thanks and thanks. I need to provide more info. Will check timing and accelerator pumps as well. Also its 6-71 bds and underdriven, but not sure how much. Thanks and i will play with it tomorrow.
    waterloo
    Look at overdrive/ underdrive. That will be a start.
    28 to 32 is a starting place.
    Hesitation with a locked advance is not a timing issue. It is a squirter or air bleed issue.
    If you ease into throttle does it hesitate, or if you whack it? The throttle...
    Wags
    BTW, with all the info you have you are going to get generalizations.
    waterloo
    OH... 6-71 and underdriven... it ain't making much boost.
    If you take off the belt, does the blower turn easily by hand, or takes some effort?
    Wags
    Quote Originally Posted by 69 wriedt flattie View Post
    All the info i have
    Mfi
    Locked distributor
    Iron heads
    Twin 750 holleys.
    100ll av gas
    Idles at 1100
    OK, I'm confused
    Screw the compression or the boost. Is the hesitation form a part throttle stab, or flat footed from an idle?
    Are these double dumper 750s? Or Vac secondary?
    Aug 2011
    central Cali
    ok from idle it responds well, if im moving good and stab the throttle, it has a real miniscule lag, then launches. my friend also suggested the squirters. so all of your advise is great.
    Aug 2011
    central Cali
    sorry, they are both double dumpers.
    Aug 2011
    central Cali
    @wags turns with little effort
