[Question] Cam Help comp cant answer!
Results 1 to 11 of 11
    Member lethal injection's Avatar
    Jul 2012
    Jerseyville Il
    Default Cam Help comp cant answer!
    Ok im needing some ?'s answered about rewarders thru hull headers and water reversion.
    i have decided to change my build to a 496 stroker. running 10.1 compression wanting to really build some rpm. running brodix heads etc. was looking at the comp cams xm296hr but no one can answer me on how the water reversion factor will be. also the second question i have is . will those headers get hot enough to do damage if i shut the water off to them at idle in a closed engine compartment?
    Jul 2012
    Jerseyville Il
    well piss rewarder says i cant run em in a closed engine compartment SOB! i dont want to spend 3,000 on exhaust
    Water injected and water cooled are two different animals as you just found out, I turned the water off to my Bassetts once and could noticed a major increase in the temp of the hull area adjacent to the tubes. No way would you want that in a covered engine compartment. My HP500EFI has the water cooled CMI tubes and run cool to the touch at all times.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    Nov 2009
    Quote Originally Posted by lethal injection View Post
    Consider yourself lucky! That could have been real bad, running a boat with a closed engine compartment changes the game abit with parts you can run "Safetly" get educated BEFORE you purchase parts. sometimes they cost more....But they are worth it in the long run.
    Jul 2012
    Jerseyville Il
    I hear that! guess im going to run logs for now untill i can afford the jacketed headers. if it runs good enough ill keep it that way. still wish i could find out if that camshaft is going to have reversion problems
    Placentia, CA
    There are some Lightening double jacketed headers on ebay at 550 now.
    steveo143 AKA DiMarco 21 II
    Jul 2012
    Jerseyville Il
    Default !
    Quote Originally Posted by steveo143 View Post
    yeah lmao thats my bid !
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    you should be able to find a decent jacketed exhaust manifold, yes they are high, but they are out there, if you want to run the covered motor.
    Placentia, CA
    Good! Those suckers are about 3000+ new arent they Somebody is selling jacketed headers new on ebay out of Florida but I couldn't find the listing.
    Jul 2012
    Jerseyville Il
    if ya find it let me know! lol i really want to close it in and just leave the carb and hat sticking out
    May 2010
    Discovery Bay, CA
    I am running that camshaft with injected headers. It idles around 950 to 1000 rpm and I have the tee valve set to allow water in at 1700 to 1900 rpm and have no problems
    Break Out AnotherThousand
