twin turbo timing
Results 1 to 14 of 15
twin turbo timing
    Senior Member TTspectra20's Avatar
    Mar 2012
    South Bay of L.A. CA.
    Default twin turbo timing
    where should i set my timing ?
    468 twin turbo 12-15lbs boost
    marine msd 6
    msd pro billet locked out
    av gas
    set timing at 30 seems a bit sluggish on the trailer only revved it to 3000 haven't had it in the water yet won't really know till tomorrow.
    Senior Member stallion176's Avatar
    I run 32 degrees locked at 18lbs of boost with no retard. I also run c16 tho
    okie, lake Texoma
    Quote Originally Posted by TTspectra20 View Post
    marine msd 6
    av gas
    What the static compression? What fuel? What heads? How much heat do you run in the engine? If you have mechanical advance in the distributer it will be a little sluggish till your all in. I prefer locked out. It will run the best if you will lock the distributer, then use the start retard function to get the engine started. Set the timing at 36* and start pulling timing after you get to 4-6psi of boost then pull it back to about 28*. this is all assuming you are around 9-1 static and intercooled on premium pump and aluminum heads with a reasonably cool engine temp. If higher static or no cooler, hotter engine, iron heads, then you'll need to be more conservative. JMHO.
    okie, lake Texoma
    Quote Originally Posted by stallion176 View Post
    Yes, and being as your intercooled,aluminum heads,and cool engine temps you could probably sneak your timing up to 35-36* on the C-16 and be fine. 1 degree at a time while watching your plugs & the tach, if you see a loss of rpms or pepper the plugs back the timing back out a degree & call it a day. Make sure the carb & a/f ratio are perfectly under control first. You'll find that it will be much more responsive with the timing in it. And you'll need to really keep your foot out of it if cruising around on pump gas.
    marine msd 6
    av gas
    I would put it on the water before adding more timing, I raced my Schiada with 30-31 degrees with a 505 cubic inch engine with a Gentry kit on it. If you have a transmission in the boat I think you will find that it's great, find a good shift point that loads the engine right and you can leave as hard as you would want in that cruiser.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    I learned the semi hard way that aftermarket Chevy heads require a lesser amount of timing.
    I'm on kill at 31 degrees on methanol with 9.4:1 compression.
    QE 439 Twin Turbo
    Ada, Michigan
    So I hear you've been kicking ass with your turbo setup this year.
    okie, lake Texoma
    I've never ran methanol but when I bought my cam from Steve Morris we had a discusion about the timing and he recommended for me to start at 32*,which he said was real safe, and creep it up to max power and that I would probably end up at 35-36* at 25psi on C-16 w/Brodix BB2xtra C&C'd heads. As far as I'm concerned he is the main authority figure on boost engines, esp blow through boosted engines.
    New Port Richey, FL
    What I meant by that was not all heads will require the same ignition timing. BB2 to Head hunter completely different chambers. LS heads different animal as well.
    QE 439 Twin Turbo
    okie, lake Texoma
    Agreed, the more efficient of a combustion chamber design the less timing required. I thought that for the most part we were talking about conv. style BBC heads.
    Thats why I asked what heads in my first post.
    Chico, Ca
    Hass, I'm curious, did steve ask you what ignition system you were running?
    Placentia, CA
    I am at 32* locked on E-85 in the green boat.
    steveo143 AKA DiMarco 21 II
    okie, lake Texoma
    Yes he did. And he thought that the mag was perfect for my setup.
    Chico, Ca
    That's not why I asked, but rather, the method of igniting the air fuel mixture can have a similar effect on timing as the efficiency of the chamber. I know you won't have any of this, but I would expect a mag to require more timing than a COP setup, simply from the characteristics of the system itself. Mags are a lower voltage, higher amps method of ignition. Recommended plug gap is a good indication.
    Andrew
