mech injection
Results 1 to 12 of 12
mech injection
    Senior Member steele211's Avatar
    Nov 2008
    Kingsburg,CA
    Default mech injection
    Stupid question here but if you have larger nozzles in the hat will that give you more fuel at the same leakdown % with everything else being the same?
    Dec 2010
    Sapulpa ok
    When u leak down a barrel valve that is the base setting then it should be adjusted to what the engine want's.The notch in the spool determines the amount of fuel at idle.Bigger nozzles will lower the system psi.The best $$$ spent would be having the system flowed. Is this a new system ??
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    If anyone knows about injection, Piston does, he has my vote, hes been from a Enderle Bird then a BAU and now that monster he has now.
    Nov 2008
    Kingsburg,CA
    Are the spools in a bird and bug different?
    Senior Member HammerDown's Avatar
    The Right Coast/SE-PA
    Question > is there a reason we don't see more "mechanical" injection boats on the water for lake river runners???
    Are they 'race only' preferred, problematic for daily use?
    [SIGPIC][img]https://www.performanceboats.com/gallery/data/500/medium/06-30-11_1234.jpg[/img][/SIGPIC]
    Led
    Led is offline
    Jul 2010
    this is EFI, someone will chime in with the reasoning with MFI,
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by steele211 View Post
    Good qustion I don't think so but there are several alc.and gas spools they even sell banks so u can grind your own notch in them. The spools are diff in the k valve & the cube
    Dec 2010
    Sapulpa ok
    Mfi.....( can be)...... tuned to drive on the lake.Mostly they are off or on wo or go. The carb is the way to go on gas at the lake. mfi is ok on alc due to the tuning window being sooo wide
    Nov 2008
    Kingsburg,CA
    In the limited drive time that I have I have found that mech inj. can be rolled into it just takes much smaller movements with the go peddle.
    Dec 2010
    Sapulpa ok
    Just need to make sure while crusin your not lean. Thats where the notch grindin on the spool comes into play
    Kent, WA
    Quote Originally Posted by piston in the wind View Post
    Do you mean the idle return slot ?
    Dec 2010
    Sapulpa ok
    Yes
