Next topic for discussion - 990 heads
Results 1 to 14 of 27
    Senior Member XClutchboy725's Avatar
    Alta Loma, CA
    Default Next topic for discussion - 990 heads
    Other than weight savings and the ability to inhibit detonation, do today's aluminum heads really flow substantially more than a good set of 990 heads?
    San Diego, CA
    Yes....try the flow sheets from AFR, Brodix, Dart.
    Hit it where you fit it
    Santee Ca.
    RHS 320's are a solid head as well, 370 ish cfm @.700"
    Alta Loma, CA
    I think the cam is curently the bottleneck on my setup.
    Old school Offenhauser tunnel ram with dual 750dp Holley's (6109's)
    990 Heads
    Cam is the old Erson JB100 - 315 lift at the cam (542 at the valve) on both sides
    Duration is 235 @.050 on both sides
    Lobe centers are at 112 (I think!)
    I would like to change to a roller set up, open her up a bit, and still run wet headers!
    Good cam combo to do that with 990 heads out there?
    Old combo revved to 5700-5800 with fresh MPD pump (Stainless AT "B" with inducer)
    Would like to improve from there.....
    Swollen Member SinisterGrin's Avatar
    Look at these flow numbers for Dart Pro 1's and you tell me if there is a big difference..................um.......that would be a yes.
    cfm
    cfm is offline
    Newer heads not only flow more, but have better port and bowl shapes, cross sectional areas, , combustion chamber design, and some are developed with wet flow. Note: Merlin's are kind of excluded from this list, although a little better than stock.
    Most, not all, have raised exhaust ports and some raised intake ports.
    Alot has been learned since the 60's/70's.
    El Cajon, CA.
    Merlin's, is that because they are an older design or?
    Thought's on ProComp heads?
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    here's my flow specs from my 990's when i had them flowed.
    http://reitanfamily.com/misc/buildspecs.html
    My heads had minor port work and the intake valves are 2.25"
    You can see my build thread on hb http://hotboat.com/forums/showthread.php?t=126180
    Hey Jeff! Finally pulling the mill to refreshen her up
    I would def step up in cam. You can achieve more with a better cam. Contact chris Straub on here and he can set you very straight with a nasty cam kit that will scare you!!!!! Talk with him about your top end kit I promise that you will be very happy
    G H E T T O F O E L I F E
    Alta Loma, CA
    [quote=Shaun;197458]here's my flow specs from my 990's when i had them flowed.
    That's what I was looking for! Some flow numbers to compare to.
    Thanks Shaun!
    I've checked out your build pics. Nice Job!
    Jeff
    Alta Loma, CA
    Yeah, She kinda forced me into it with the oil pump taking a dump on me.
    It's been a nice strong and reliable motor for years. Time to step up though....
    Thanks for the info!
    Jeff
    San Clemente, Ca
    just remember my 990's are not stock!
    Default Heart of the motor
    Quote Originally Posted by XClutchboy725 View Post
    Jeff
    Any question about which "out of the box" oil pump to use?.............MP
    LOUD BOATS SAVE LIVES
    Newton Ks.
    Just keep in mind engine size and intended RPM.
    More flow is not always better. Beyond a point, it will hurt you.
    Here is a VERY hard running set of factory irons:
    2.19" intakes, 1.80" exhausts, on 11/32" stems
    Lift ---- Int----Ex
    .050 -- 31.8 -- 26.1
    .100 -- 67.2 -- 56.8
    .200 - 146.3 - 113.0
    .300 - 221.9 - 147.0
    .400 - 270.7 - 176.6
    .450 - 277.0 - 189.8
    .500 - 283.4 - 198.6
    .550 - 291.8 - 201.9
    .600 - 297.0 - 203.0
    .650 - 297.0 . 204.1
    That's better than 990's from the box, and mine are not rectangles, never were.
    Those produced a VERY hard running 454 that otherwise is "handicapped" by 8:1 compression and a hydraulic cam (and 1 too-small carb on a dual-plane Perf. RPM Air Gap intake).
    It makes 500HP at 5,400RPM, Aggressor B impeller in a Berk F, no inducer (but now blows the pump dry if I stomp it from idle (never did that before)).
    Spun her to 5,900 with the big nitrous jets 2 weeks ago teaching a TX driver a thing ot 2. LOL
    Just don't go TOO big looking at head flow unless you have a huge motor or intend to spin huge RPM.
    Something that fits will work wonders, something that does not, will require duct tape and bailing wire.
    H.L. Mencken
