468 cam help
Results 1 to 14 of 64
468 cam help
    custom member raped southwind's Avatar
    so-cal
    Default 468 cam help
    need some help on chosing a cam. I want to run a mech solid for cost reasons as the budget wont allow roller at this time. Current set up is as follows.
    468
    ported 049 heads with 2.30/1.88 valves
    arais forged pistons looks like 10.8 compression with a .041 quench
    forged crank
    Carillo rods
    arp studs on the mains,heads,and rods
    victor intake and 4150 850 set up to flow 930cfm
    this is going in a 21 daytona with a ss "A" impellor
    Will be a play boat but want to hul the mail
    Thinking comp 294s
    248 @.050 [email protected] .050
    .595 lift .595 lift
    110 LS
    106 CL
    installed 4 deg adv
    or
    Comp 306s
    [email protected] @[email protected]
    .629 in .629 ex
    110 LS
    106CL
    Any opinions or other options
    El Cajon, Ca.
    Call Schneider Racing Cams... 619-297-0227
    Talk to Jerry or Kevin... they will hook you up with a cam that will work great. I have built simmular combo's using their "ZL" flat tappet grinds and been very pleased with the results. They can taylor it to suit your needs specifically rather than just trying to find one that "ought to work, close enough."
    Mar 2010
    Clarksville, TN
    Chris Straub @ 423-391-7774. He'll take Great care of you
    Nov 2009
    Clay Smith Cams Buena Park, Ca 714 523-0530
    so-cal
    Thanks everyone. Seems like i missed calling everyone today ( time difference) or they were in sonoma for the races. Looks like Barry is gonna look into having one ground for me.
    Tri-Cities, TN
    I won't sell a flat tappet to a racer. To many issues that I have no control over. BBC are the worst with their lifter bore angles.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    so-cal
    No racer here The boat will be a lake boat/hot rod and get run mabee 3-4x a day. I try and run the river a few x a yr but norm just a local small man made lake where we camp and bring out the floating living room( mastercraft wakeboard boat) ! It holds enough beer and water for 15-20 people and enough radio to hear it lake wide! But thanks for the heads up!
    Tri-Cities, TN
    Cores are not what they use to be and lifters are not even close. I am at 27 roller cam replacements for failed flat tappets this year. Flat tappets to me are Russian Roulette. I understand the cost factor but if the flat tappet fails what is your time worth and materials to do it all over again. A hyd roller and it is done, go boating.
    Chris Straub
    Straub Technologies
    Just went through this with a custom FT grind from a very well known manufacturer. It went flat in less than 10min. on the break in stand. Wiped out half the lobes. All the proper precautions were taken, good EDM lifters, etc.
    You pays your money, you takes your chances with any...and I mean any FT cam.
    Nov 2009
    Whatever! HMMM I just don't see it, I see more cams than you and chris BOTH!
    LOL... Yeah, we're lying. That's it.
    so-cal
    thanks for all the help and/OR trash talk! Wasnt asking for opinion on roller vs flat . I have enough info to make a decission!
    Nov 2009
    Your not lying, But why is it YOU and Chris are the only ones "Sniveling" about flat tappets? When is the last time YOU even built an engine with a flat tappet? Since Chris doesn't even Grind Cams....Maybe the place HE orders them from just SUCKS! Ever consider THAT? Maybe his "Cad program" needs an update?
    Jul 2012
    Chris,
    There are some applications where a hyd roller is a very suitable solution.
    It might be hard for that Hydralic Roller lifter to spend enough time on the seat at high Rpm To keep prime. No prime leads to a SMALLER CAMSHAFT (duration and lift)..
    No prime on the lifter can also do funny things to pushrods. like bending and jumping around.... And im sure you know what happens when a roller lifter breaks...... its a needle bearing easter egg hunt in side the bottom of your Engine.. To me thats a Russian Roulette Game as well.
    OF course none of this applies if you have some type of rev limiter device.. (but...MSD CAN GET EXPENSIVE) $$
    So With that being said a 18 foot jet boat that can rev 6 to 7,500 at a blink of a eye, (hoping out of the water, Blowing the pump away at launch...Or in some cases a horrible pump job...etc...or i even seen some guys have problems with weeds and or grass..lol) HYD roller might NOT be the best for a smaller boat applications. But with this one being 21 feet should be fine>?<
    Nic
