power limit on gm block
Results 1 to 14 of 31
    Senior Member stallion176's Avatar
    Default power limit on gm block
    Just curious as to how much grunt a stock block will take. I'm at 1200 or so on my 496 4bolt deal. Thinking of stepping it up some more. What is too much?
    Dec 2010
    Sapulpa ok
    IMO your there
    Tri-Cities, TN
    Its not a matter of if at this point, it is a matter of when it will go.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    It has probably 50 passes on it and so signs of fatigue. Guess I should count my blessings. Haha
    It won't warn you. Turbo power is definitely "easier" on things, but IMO you're there. The answer is really "whatever it'll take". Problem with limitations is, you never find them till you exceed them.
    Kent, WA
    We are using the stock block, made 1400 on the dyno, it now has two years of run time on it ?
    BUT, I leaned on it a little too hard in Burley and hurt one piston, so we had to take it apart and replace that piston.
    The engine is very nice inside, even after the two years.
    Stock caps, 445 casting from a 89 Suburban !
    Nice. What power adder
    Like Pat Eason would say, you're racing with the engine from a MOHO!
    SOOOOOO Brain, is that block filled?
    I have NO doubt that (BEAUTIFUL) beast makes every ounce of 1400, but does Too Tall REALLY make that much THE ENTIRE RACE while kicking ass up and down the track?
    Think Charlie was asking more of that stock GM block than Bill was demanding of the one in our boat.
    Quote Originally Posted by stallion176 View Post
    Its a blown alky that runs ALMOST as well as it looks.
    Kent, WA
    TBS 8-71 Delta Retro Billet case @ 25 over
    Kent, WA
    It is not filled at all. I've thought about trying that only to see if it would retain some heat ????
    The big guy is getting more comfortable driving it, seat time is good.
    Fresh engine in it for the Beach !
    ( I'm still waiting on a new piston for the "worn out" engine )
    Icy
    Icy is offline
    Boatless Member :( Icy's Avatar
    Aug 2009
    AV, CA
    What happened at LB to the motor? Did you tear it down?
    Douglas, MA
    I have been wondering this myself...I would like to step up to a 496 rotating assembly from my current 468 and put about 15lbs of boost to it...I just wonder it that isn't asking a lot of a stock 4 bolt block.
    Jun 2011
    spokane, wa
    468 chevy stock block, 14lbs of boost from an 8-71 and a 300 hit of nitrous in a 32 ford coupe, makes 1,032 to the rear tires and have been running the same block for 12 years!! The car sees about 100 miles of street driving a week and may 8 second passes at the strip, it gets beat on!!
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    Aftermarket blocks are intended for power, stock blocks , but i run a 445 block and have seen many stock blocks and even iron headed blown alky deals be worry free all season making 7-8 passes at the races.
    After a build or two i do ask myself then I look at the sponsorship funds...$0. Run what you brung! then if or when it comes apart! then Repeat!
