What dizzy gear?
Results 1 to 5 of 5
What dizzy gear?
    Senior Member lilrick's Avatar
    Lakewood
    Default What dizzy gear?
    On my stock roller cam in a gen 6 454. Ive never personally run this engine but a steel gear came on the dizzy that i got with the boat. Can i run it?
    Quote Originally Posted by lilrick View Post
    Stock roller cam engines use melonite steel gears on stock roller cams. So long as the thing doesn't have some .750 lift roller, it will be fine.'
    Is this the dizzy that came in the boat, or one that was handed you when you bought the boat?
    Lakewood
    Its the actual dist that came out of the motor. So, do i need to run that gear if i changethe dist? I have a DUI id like to run instead of whats in there.
    I would switch the gear.
    Rick, did you miss me?
    Lakewood
    Yes i did.
