351 Flywheel..
Results 1 to 7 of 7
351 Flywheel..
    Senior Member =River Perfection='s Avatar
    So Cal/Parker Strip
    Default 351 Flywheel..
    Looking for a 157 tooth flywheel off a '86 ski boat. Boat has a pleasure craft 351 Winsor with a velvet drive. Ring gear is smoked and I cant seem to find a new one. Any help would be great.
    Might be a dumb question since I am not the Ford guy, but is the ring gear itself replacable?
    Brian
    Cantard 71hallett's Avatar
    snow bank
    Can you use one out of a stick shift mustang or truck?
    snow bank
    Summit has them. Hope this helps. Man these things arent cheap.
    http://store.summitracing.com/egnsea...15&Nao=0#rstop
    snow bank
    Sooooo.......??
    Did you find one?
    So Cal/Parker Strip
    Yes... got one and it worked great. Did a little research and was able to get one through a place as easy as autozone. Thanks for all the help.
