engine breather question
Results 1 to 14 of 23
    77 sleek. corbin5754's Avatar
    Aug 2011
    indy.
    Default engine breather question
    Can I put breathers on both valve covers or do I need a PCV valve setup on my bbf.
    Oct 2011
    I just went thru this problem. Got rid of PCV and went to breathers on both covers.
    Aug 2011
    indy.
    Quote Originally Posted by rpm0414 View Post
    Cool so I'm taking it, it will be fine if I do the same.
    Senior Member Jake's Avatar
    Quote Originally Posted by corbin5754 View Post
    If the breathers spew oil add a puke tank.
    Aug 2010
    dual breathers here... mooneyes makes some nice ones.
    Member 77CenturionJet's Avatar
    Jul 2010
    Fairfield , Ca
    Make sure your valve covers have baffles or they will spew oil
    Aug 2010
    Quote Originally Posted by 77CenturionJet View Post
    no oil spewing here. if you have oil spewing out of your breathers you have bigger problems than baffles...
    mmmnot so sure about fords, per se,
    - but I can say I've been running speedway (dual breather) valve covers for some time now because I was weeping out of a single breather, and going to twins fixed it.
    It started when I wrung out the setup a bit more from flat tappett to a hot hydraulic and did a bit of porting work. Seems to create more crankcase pressure and one hole per cover had a weep- the Duals work perfect neither arent even moist. Dont need a spew tank.
    There is nothing remotely wrong with my mill.
    Uncle Dave
ID:	172051   Click image for larger version.
Name:	406 New Dist: Coil.jpg
    Senior Member SBjet's Avatar
    Vero Beach, FL
    No fag jokes from the old HB crowd?
    Quote Originally Posted by Tom Brown View Post
    I'm still chuckling at being "poo-pooed" for straying off topic. Awesome.
    Quote Originally Posted by ka0tyk View Post
    if the motor is blown, it is common.
    Quote Originally Posted by Jake View Post
    Thats true all my blown motors have catch tanks for breathers an i have to drain it every once an awhile
    I think the location of the breather on the VC could be part of the problem also. On a BBC with a normal valve train layout the pushrods are aiming oil at the area where the breather is positioned, even with an engine that has very little blowby I can see where this would add to the seepage problem. On my 565 when it came time to mount the breathers I located them on the vertical surface of the VC near the intake manifold and out of the area where oil is being directed to spray in the area of the breather. Four years and 50+ hours and not a hint of mist let alone a mess.
    Senior Member jamesblown97's Avatar
    Mar 2011
    st george ut
    i run dual breathers and no pcv on mine with no issues
    Aug 2010
    Quote Originally Posted by neil450 View Post
    sounds like i need to get me one of those to make sure my breathers are working properly.
