350 mag mpi help
Results 1 to 2 of 2
350 mag mpi help
    Senior Member ohflat's Avatar
    Nov 2008
    Default 350 mag mpi help
    need help shift hard to get out of gear and poor preformance shift interruptor switch does not work when i depress it it has 2 switches on it it is a alpha drive also check it with ohm meter and appears to work ok one swicth has 3 wire deal basicly going to ground the other one is 2 wiredeal
    Jul 2012
    Quote Originally Posted by ohflat View Post
    Could be a bad cable stretching or out of adjustment. If the switch does not work and it checks out okay then you need to get a wiring diagram and go through all the wiring. I would start by checking the rigging on the cables all the way down to the outdrive. Make sure everything is in rigging specs.
