best way to clean tranny fluid
Results 1 to 11 of 11
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default best way to clean tranny fluid
    Wondering if any of you guys have any recommendations on how to clean tranny fluid (ATF4) up off asphalt? I've tried the methods I use for oil and it only made the problem worse. I know the local auto parts stores have a few products claiming to do this safely but i don't want to drop $100 testing every product they offer.
    From a popular commerical " if it won't come clean with super clean, it won't come clean ". The purple stuff has allways worked well for me, you may give it a try, the purple stuff from Castrol.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    Senior Member XClutchboy725's Avatar
    Alta Loma, CA
    Anything like Castrol Super Clean or other degreasers is going to also dry out the asphalt. You may have better luck putting something down to absorb the ATF. Kitty litter or ash sweep for example.
    Tower Park Resort, Lodi, CA
    Default *warning*warning*warning*
    You know how everything has a warning on the label about wearing gloves, don't get on your skin, protect your eyes... blah blah blah?
    If you try the purple stuff... WEAR GLOVES! And try to not even get it on those!
    Been there done that. Was even warned by the guy who recommended it... my Dad. Probably why I didn't listen. LOL
    Will pull all the oil out of your skin and a couple days later the palm of your hands painfully crack open and resemble 100 grit sandpaper.
    The good part of it is, it will probably get you out of any kind of massage your wife/GF may want you to give her.
    I've never tried it on the oil you speak of, my guess is it's your best bet though.
    Keep us posted on what works out in the end. And...
    Good luck!
    -Seth-
    San Clemente, Ca
    Were can you get that stuff? Called a local autoparts store and they guy said that it's not around anymore because the EPA. He has the super clean version which he says is no where near as strong.
    Any Pep Boys or Auto Zone has it. It nasty stuff. Like Xclutchboy said, it will probably pull oil right out out of the asphalt. Don't get it on anything painted. It will even destroy anodizing.
    If the EPA got to the stuff, I wouldn't be surprised, but its a new ne on me.
    Arroyo Grande
    Tide Laundry detergent..(powder) sprinkle it on there ..wet it a bit..scrub gentle...hose off....
    Zep Morado Super Clean is pretty much the same stuff. You can get it at Home Depot in gallons and 5 gallons.
    Serious stuff. DO NOT UNDERESTIMATE THE STUFF.
    SDBA #819 vdrivegrimes's Avatar
    Oct 2011
    Muratic acid
    Senior Member slow67's Avatar
    DFW
    Quote Originally Posted by vdrivegrimes View Post
    Muratic acid
    X2. Just watch out for the yellow smoke
    Maple Ridge B.C. Canada
    brake clean
