Carb Spacing on a tr2x
Results 1 to 9 of 9
    Aug 2011
    placentia,ca
    Default Carb Spacing on a tr2x
    Im going to install a Edelbrock TR2X tunnel ram on my BBC maybe thursday and i need to build a new scoop tray. Im running a pair of 600 holleys inline. My boat is in storage and sort of a pain in the ass to drive there for a measurement that isnt going to help me. My brother has a shop that can make me a scoop tray but i need dimensions of the center to center of the carb spacing. I measured the manifold which is at my house and the mounting studs are 10" center to center. The holes in the manifold are also 10" on center. I wont have time to make a new tray using the boat since my brothers shop is about an hour away and the boat isnt together yet. Any info or direction would be great thank you
    My question is:
    Does anyone know the center to center dimension of the carbs installed inline on a TR2X tunnel ram?
    Is the 10" number im getting correct?
    Mar 2010
    Clarksville, TN
    Seems like it was 9 7/8
    If your carb studs are 10", then your carbs will be 10".
    Certified Wildman! Sanger Flatbottom's Avatar
    May 2010
    Antioch, Calif (NorCal)
    I believe mine are 9 7/8" as well
    Everything electrical has smoke in it.... and it's not done till you let the smoke out!
    Aug 2011
    placentia,ca
    I have seen that number around a bunch. Sounds great thanks guys. I just sent my brother the numbers. I'll keep my fingers crossed
    Southwest corner AR
    This is the older style intake right? (TR2X) The Victor 2-R has the 9 7/8" spacing I bet TR2X intake is 10"! But, 1/8" can be worked out if it is to tight!
    WT
    WFL Crew!!!
    Aug 2011
    placentia,ca
    Yeah it's an older style one. Click image for larger version.
    Mar 2010
    Clarksville, TN
    I got a nice SS fuel log for that intake if ur interested.
    Quote Originally Posted by SofaKingFast View Post
    Well that saves me the trouble of going out in the garage and measuring the old top I had on my Victor 2R, before I replaced it with one of CARNIVALRIDES beautiful machined billet tops that also turn 4150's sideways and incoporate a " Super Sucker " type transition from 4 hole to open plenum going into the stock bottom half. Great piece at a very reasonable price considering the cost of the chunk of material needed.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
