Choosing the right piston?
Results 1 to 13 of 13
    Southwest corner AR
    Default Choosing the right piston?
    I am in the process of building a new motor and am looking for info. on the best piston to run in it! This will be around 10- 11 to 1 compression and the kicker is I plan on spraying the chit out of it! Maybe two stages 500 +! What would be the best material and or brand to run at a fair price! Any info would help! And I know some of you know what not to run at all!
    I know each has there on brand that they like so no piss matches over brands! I just need to know what has worked best for some!
    Senior Member SBS933's Avatar
    Jun 2012
    Keith Black
    Quote Originally Posted by Slow Boats Suck View Post
    Keith Black
    Doubt there will be many fans of hypuretic or how ever u spell that here. I will be watching this thread close.....wanna up the compression on my mill soon. I asked a piston q a few months back and t sunk like a rock.
    WT....are you chambers 118 ish??...just curious what head you have.
    Lot of spray. Ross for me. I would build more motor and less juice.
    Im guessing a CP with a Embee coating....
    Widetrack, you simpl;y cannot make a statement like this. Specially when you're talking about 11 to 1 and a 500HP hit.You need to get your priorities straight. HP or budget.
    Of the "bargin" pistons, I guess the Icon is the best for nitrous use It has pretty decent reinforcement under the dome and the ring pack is further down the piston than most. It also has a pretty stout short pin.
    I put a Ross in my lawn mower once. Decades ago.
    Always amused at the idea of taking a wrecking yard motor and hitting it with NOS till it comes unraveled. Theres never a shortage of people that will try to make 1000 HP on a 500HP budget.
    Senior Member Ronboats's Avatar
    Norcal-Santa Rosa
    Call Diamond Racing pistons for a top of the line racing piston.End of story.
    Southwest corner AR
    Yes 118 or so! Brodix BB2 that will have some good work done to them! Eldebrock TR with work done also!
    Hahahaha! Bob, You pick out things don't ya! Yes I put the two together but, fair to me can be in a very wide range! Whatever it takes is what I will use! I am not building a junk yard motor I am getting my parts together and type of piston material is of my concern for the NOS, not brand as much! I don't run junk in my opinion but to others it may be! To each his own!
    Now back to the question! Type of piston material is best for NOS use? And if there is a off the shelf brand that would be best! Or would it be best for a set of custom pistons to be made?
    There that better Bob?
    The material needs to 2618. Thats the easy part.
    Like I said, if your hitting it with 500 HP of spray you need to consider a custom piston from CP. Otherwise I would throw a set of Icons in it.
    Southwest corner AR
    Thanks! That was the info. needed! I will see what I need before I get them made!
    Mohave Valley/Quartzsite
    I agree with Bob on this.. Brian over at CP will build you a piston for your combination and it will be the right one!! I would steer away from an off the shelf piston with that much NOS but I can't tell you the last time I bought an off the shelf piston so I probably don't have a clue anyways..
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    Where ever you go,make sure they get the valve pockets in the right location.This is a issue with most production shops.
    A shop like REBCO doesn't make theses mistakes.
    DFW Texas
    Widetrack have you poked around the yellow bullet forums ? I believe there's a few guys that play with the bottle over there
    Yellow Bullet Forums - Powered by vBulletin
