Blower motor timing, locked out or curve?
Results 1 to 7 of 7
    Senior Member Smallblocksperry's Avatar
    Jul 2011
    Default Blower motor timing, locked out or curve?
    2003 26' american offshore
    just built a 540ci
    dart big m block
    dished JE 8.25-1 pistons
    merlin 345 iron heads, ported/polished
    billet solid roller .252/.262 @.050 .652" lift 114 blower cam
    comp rockers/stud girdles
    imco powerflow exhaust
    littlefield 8-71 blower/intercooler
    dual 750 holley carbs mechanical and electrical fuel pumps
    8% overdriven right now, wont know boost numbers until i get it running, what kind of boost will i be safe at with pump gas?
    with pump gas, what kind of timing curve should i put in it, with what final timing? or lock it out?
    how about carb jetting, does anyone have any experience with a similar setup? powervalves?
    any info much appreciated
    Jan 2012
    lake Charles, Louisiana
    Iron heads, better be conservative on that total timing.
    Myself, I always lock them out, anywhere from 28-34 depending on compression, boost, blower type.
    I would think 30 total would be a close starting point. Shoot for around 10 lbs of boost
    On carbs I dont really like power valves, I block them and up the mains 4, then add another 8-10% again to the mains
    these are my opinions only from ones similar I've built and worked decent
    The member 1bdhondo's Avatar
    ca
    Lock it out .... You dummy
    Quote Originally Posted by 1bdhondo View Post
    DUMMY? I take it he he is your brother
    That isn't some 1500lb flat bottom. Not everything pops out of the water at 2500 Rs
    I think I would start with a curve. It cost ZERO to change it.
    Just my opinion, but your already overdriven too much. If thats a typical Littlefield blower, I back it down to around 1 to 1 to start. I doubt you'll ever get it passed 5% over on pump.
    Jan 2012
    Didnt even see the american offshore line, I built an almost identical 509 bbc 8/71 blown bbc, with some brodix heads, intercooled, that went in a 26 American Offshore NSX. 748 hp and 104 mph
    Jul 2011
    Quote Originally Posted by SHAWN DAVIS View Post
    What size prop, gear ratio, drive?
    748 sounds like a pretty conservative tune up, I was shooting for 900
    Either way 104 sounds good enough for me
    Did u run it locked out or a curve ?
    Jan 2012
    If memory serves me right, bravo 1 1.36 28 pitch 4 blade 6000 rpms, pretty conserative yes,had 950 hp carbs. 900 hp will be tough w those heads, blower and carbs. locked out at 30 degrees, think that was w a regular hydraulic cam. Switched to a solid roller after a year or so but didnt put it back on the pump to check it.
    Owner couldnt work on it himself so I built it around his skill level-(oil changes only)
