Oil Pressure
Results 1 to 14 of 29
Oil Pressure
    Senior Member PlacecraftTunnel's Avatar
    Wittmann,Az
    Default Oil Pressure
    What will to much oil pressure due?
    Quote Originally Posted by PlacecraftTunnel View Post
    define "to much" ?
    S CP
    Wittmann,Az
    idle is at 75 psi & goes over 100 when it the throttle.
    I will start the list of bad things that to much pressure can do. It is hard in dist drive gears and pump drive. It can rob horsepower. In theory it can effect timing due to the pulses the pump can make. It washes bearings. Can damage seals. Can drain the pan at high rpms. Now let the ass kicking begin.
    Nov 2009
    100lbs 6000rpm
    Surprise, AZ
    Frank, is this a new motor?
    Wittmann,Az
    I was hoping for different answers, but i figured all the above answers. Good thing its still on the stand..
    Wittmann,Az
    100lbs 6000rpm
    125lbs at 4500rpm
    Wittmann,Az
    Quote Originally Posted by 67weiman View Post
    Ryan no its not. Still building mommas motor. It will be ready when the new boat is done.
    125lbs at 4500rpm
    uhmmmm try some 05-20w
    what pump do you have on it?
    S CP
    I think Evil nailed the down side pretty much. Also sleeper questioned what pump but I would be concerned as to why so high? By-pass issue, really tight, and what oil?
    85-120
    S CP
    If your not pumping straight 70 WT COLD, then you pump pressure relief is stuck.
    Although Evil nailed some of the problems, he threw in a couple that have never been fully explained to me. Like what a washed bearing is EXACTLY, and what seals aside from the oil filter is under oil pressure.
    Its hell on you dizzy gear, specially if its bronze, and it messes with your timing and will put more oil in you heads and throws excessive oil all the crankcase that you really don't want, and adds to foaming. Sucks power but thats the least of your issues.
    I have seen oil washed bearings and its not a pretty site. Burned and rolling babbit. Much like a fuel wash but more drastic. As far as the distributor gear if he is running a roller (or not) in will multiply cam walk ten fold. Not to mention pumping ALL the oil up top and draining the pan As far as the relief stuck, I would bet on that as long as the build is right and he is not running gear oil! MLAO.
