burst panel pop
burst panel pop
    WHITTIER CA
    Default burst panel pop
    i took my eagle out on sunday morning at the river. boat runs super good, first time running off the dyno. and bang i blow a burst panel at about 15 pounds on the guage wich is 4 more pounds then it made on the dyno. i did it twice on sunday. it was the same bolth times right about 5800rpm. any thoughts ???
    blown bbc
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by SCSRIVERRAT View Post
    blown bbc
    Sounds like it's lean
    Kent, WA
    Lean or watch the water temp being cold and sticking an intake valve !!!!
    WHITTIER CA
    Lean is a good thought, its just so frustrating after spending all that time on the dyno getting the right jets in..
    By boat temp is about 130 would that be cold enough to stick an intake valve?
    Thanks for the input
