Alternator
Results 1 to 14 of 14
Alternator
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    Default Alternator
    I bought a new 1 wire mini alternator. When I connected the wire I could hear a humming noise coming from inside the alternator. Thinking that a small load is being drawn I returned it and got another one (same). This one also has a hum noise when I connect the wire. Is this normal for some alternators? If it is making noise it has to be drawing amps, right?
    Rareelectrical.com - NEW CHEVY 60A MINI ALTERNATOR 8162 WINTERS & RICHMOND REAR ENDS 1 WIRE UNIT
    Tim, the alternator doesn't really draw amps, it generates them. If your battery is really low, it will produce the most current (amps). About all you can measure is battery voltage and battery should be around 1 volt higher with the engine running than with the engine off. This is really the only indicator it's charging.
    My East Coast Electric don't make any noise you can hear over the engine. The hum must be pretty loud if you can hear it over the engine. "Listen" to the bearings with a screwdriver and see if they sound bad. Cant' think of a reason it should be humming...
    David, I may be wrong, but I think he means it makes a hum the second he hooks it up, with the engine OFF!
    If thats the case, it seems very wrong to me. I don't need something that hums while its sitting in my garage.
    Lake Havasu
    Yes it hums when I connect the wire. Engine is not running
    I had one of their chrome minis and it took my battery down during the trip to firebird from san diego, with the master disconnect off. Just brushing the one wire to the terminal caused a small spark. I put the black one I had back on no problems. Im thinking an internal short or something in the chrome one. The chrome one got hot with the charger on it also. So I just swapped it out.
    Oh, if that's the case, something is definitely wrong and I got nothing....
    Lake Havasu
    Going to return it and buy this one
    http://www.summitracing.com/parts/ECA-2025/
    Quote Originally Posted by Master Sergeant View Post
    MS, its my guess they have a problem with their diodes. Maybe a run of alternators with them installed backwards? Who knows.
    You get this from RareElectrical off Ebay by chance? Just curious?
    The East Coast Electric is a good PROVEN performer.
    Tim, sounds like either a bad voltage regulator, or a questionable "one-wire" conversion, allowing the field circuit to remain "on" at all times. Although that RareElectrical unit that looks like a NipponDenso Ultra Mini as sold by ECAE and Powermaster, the price screams Chinese "replica" and the quality control that comes with it........
    The price AND the marketing both SCREAM Chinese knockoff.
    Lake Havasu
    Yes, RareElectrical off Ebay
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    You may have just had bad luck. I have one of the mini rare electrical alternators, as well as many folks I know. No issues so far.
    Good choice Tim. There a bit pricy but the quality is worth it. You seem to have my luck where everybody gets by with cheap knock off stuff and I never do!!
    Senior Member racer's Avatar
    Dec 2010
    Default china junk
    sorry ...buy american.
