My pump gas 489 build for the old Hondo
Results 1 to 14 of 79
    Derby, Kansas
    Default My pump gas 489 build for the old Hondo
    Well as some of you know last summer I grenaded my old 467 that had been with me since 1992. Back after. 2004 I raised compression, did some additional porting on the heads and added more cam thinking I was going to go racing again. To make a long story short after building that engine up to run expensive gas I only raced a half dozen outlaw races and never did make a sanctioned 1/4 mile race. So after losing the crank, block, cam, some rods and a couple pistons I was faced with the decision to piece back together my favorite combination to date or to use some parts I had collected for another project and go back to a more easily available and cheaper pump gas engine.
    What I had was a new bare set of AFR 305 heads I had ordered for my old 467, a Velasco 4.25” stroker crank, a set of 18cc dome .030” over SRP pistons I picked up for a screaming deal (for the 4.25” stroke) and a couple of blocks I thought would clean up at .030”. So the debate over compression or cubic inch started, lots of different theories here. In the end it came down to all I had was 6 pistons out of my old build and only cast 4” stroke cranks. I needed rods either way so that was a moot point. So I decided to try the 489 hoping the additional cubic inches would offset the compression loss and the new heads would give me a little more power than I had before.
    So here was the donor block, which was supposed to have been running when it was pulled. I didn’t take pictures of the inside but trust me if it had been running it sat outside uncovered for a few months minimum. Piston rings rusted to the bores and a valve cover full of dirt led me to that assumption. Lol
    The core motor as I got it home, but it was free since I picked it up. Lol
    After 2 cans of oven cleaner and $10 at the high pressure car wash.
    As usual I got a little carried away on clean up and deburring
    Derby, Kansas
    Default Well the stroke wouldn't quite clear
    Well I used a stock piston on one of my new rods with the stroker crank to mach this part up. The oil rail was clearing but off center so I had to even it up and added a bit of clearance with some radiusing. However the rod hit the oil galley and it took some grinding to get the clearance I wanted.
    Some cam galley clearancing
    oil rail clearancing
    rod bolt clearance oil rail
    rod clearance cam galley
    Peoria, AZ
    Oh, you have me all excited. Can't wait to see it each step of the way.
    Paul
    adjones419 Wet-n-Wild's Avatar
    Shiloh, IL
    Nice dog turd in the making you have there, Loren!
    Derby, Kansas
    Paul
    Quote Originally Posted by Wet-n-Wild View Post
    Thanks Paul & Adam, the thread is actually behind it has been fired and ran. lol
    Your momma didn't raise no dummy. Never post a build till you know if it works.
    Derby, Kansas
    Default Bore notching
    Well after spending so much time deciding on heads, porting them and having them flowed I just couldn’t bring myself to slap them on the round bore. As many of you know the intake portion of an open chambered BBC combustion chamber over hangs the cylinder of a 4.28" bore by a fair amount. After all the flow work I did on my heads the idea of my intake airstream crashing into that ledge bummed me out so once again I got out the layout fluid scribe and grinding tools.
    Close up of one cylinder with bore notches
    One bank done
    And one after initial boring
    Derby, Kansas
    Thanks Bob. lol
    Derby, Kansas
    Default A few more
    Here’s a piston
    Checking TDC
    Checking deck height
    Derby, Kansas
    Default High lights from the heads
    Peoria, AZ
    It's about time you picked this thread up. LOL
    Paul
    Derby, Kansas
    Paul
    Well I wasn't seeing any comments so I didn't think anybody was reading it.
    We may be overwhelmed, Its the same as; better to listen and learn. Keep posting, I noticed the clearance for the Intake, have heard it mentioned but always forgotten.
    BB
    Nice Work there Loren, hope it serves you well.....
