How level should a carb set?? jet extentions?
Results 1 to 14 of 34
    Default How level should a carb set?? jet extentions?
    I was noticing the other day my carb leans backward(I know that sounds dumb) so my q? is A: should I get a carb spacer to level it out. or B: just get some jet extentions (for the secondaries)and don't worry about it?
    Cantard 71hallett's Avatar
    snow bank
    Extension kit and drive on.
    and a notched float back there
    snow bank
    Kit was the key word!! lol
    oooopps, my bad
    Default carb spacer?
    It sits so far backward when I look through the sight windows, in the secondaries all I see is brass(float).
    snow bank
    What intake are you using?
    vic jr. 4150. rail kit is set dead level with the stringers. I dunno seems like my secondaries aren't kickin in.. I just see the carb leaning back and me accelerating away from the fuel.
    snow bank
    You should be fine with that intake. If the extensions dont do it the bowl is empty.
    This is what I'm lookin at
    Lurker
    NC
    What carb is that??
    It appears to have a 50cc arm on the secondaries (strange for a 4150), it isn't a spread-bore is it?
    No spread bore. Just 800 dp. You can't really tell the angle in that pic unless you look at the floats.
    snow bank
    Something is up with that float. Better pull the bowl and take a look. While you are there add the jet extension kit. lol
    snow bank
    If that is realy the float level fuel would be running out of your down legs.
