cam selection
Results 1 to 2 of 2
cam selection
    Default cam selection
    Here is what im trying to do my buddy has a 23 or 24ft eliminator mohave its a big heavy boat we have the short block together right now its has flat top pistons,gm rods with arp bolts, cast crank, we are going to run a set of 049 oval port heads looking for a good hydraulic roller cam for it nothing custom just something that runs good up to 5k or 5200 rpm it has a bravo outdrive, it also has the stock mercruiser manifolds.
    just looking for something off the shelf that i can put in it thats not a ton of money but we are willing to buy good parts or something you guys have ran and had good luck with.
    i know im going to take some crap for this posting but its not a 1000hp motor or anything if we could make 450 with it we would be happy.
    Tri-Cities, TN
    With the Merc manifolds you need to watch your adv. duration numbers. They won't take alot with out reversion. 400HP you can do with stock manifolds but not 450HP
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
