Mag and tacks
Results 1 to 14 of 35
Mag and tacks
    Cantard 71hallett's Avatar
    snow bank
    Default Mag and tacks
    Can I still use the - terminal on my coil to run the tack. Using the super mag III with external coil.
    Paul
    snow bank
    Gona try it I guess.
    Peoria, AZ
    I would say no being that the voltage is not constant like it is on a standard distributor.
    Paul
    Call Autometer's tech line. I think their part # 9117 tach interface is what you need. I'm using one with an internal coil vertex, but the instructions also show how to use it with an external coil mag. I had trouble with the tach freaking out at high RPM due to solid core plug wires. I swapped to suppression wires and it seems to have fixed it. Won't know for sure until we can deck the throttle and see what it does at high RPM. Hope this helps and good luck.
    snow bank
    Autometer pn# 9118 for me. Thanks for the heads up!!
    snow bank
    Well the 9118 doesnt work. How did you make out with yours?
    Senior Member Morg's Avatar
    Reno, So close to hell you can see Sparks.
    Make sure you wire it exactly like they show in the directions, With the trigger wire & the ground trigger wire on each side of the mag kill switch.
    I started to buy the 9118 based on what the Summit on-line catalog said. I ended up calling Autometer before I ordered. They told me the catalog wasn't completely correct and to use the 9117. Call Autometer's tech and make sure, but the 9117 looks like it will work for both internal and external mags...
    We still haven't had a chance to run the boat all out and prove the tach works throughout the RPM range. We are scheduled to test soon, certainly before Bakersfield. Also we're trying to make CFW next week, but my work schedule is kinda insane right now so not sure we'll be able to work that out. Good luck.
    WORK! We don't need no stinking work. How's it goin David? Got all my alum. back from the anodizer, came out killer. Now I really need to get goin on a motor. Stop by and check it out when you get a chance, as allways up for a delta trip anytime.
    Larry
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    snow bank
    I wired it like the diagram but in the install notes it said may not work with solid core wires. Didnt say anything about that when I ordered it. The new converter is still cheaper than new wires sleves exc. so I guess I will have to try that.
    Not sure if you got this worked out, but we had to change our wires. We originally had the solid core wires from Hunt. The tach worked OK at low RPM, but freaked out after about 3500-4000 RPM and then pegged 9000 RPM shorthly after. We switched to suppression wires and it seems to have fixed our issue up to about 5k RPM. Will have to wait until the boat is in the water to check any higher.
    Hope you get it figured out.
    snow bank
    I just ordered the box you have 9117 is it going to work or do I still need to change the wires?
    Ours didn't work properly with solid core wires. We had to change them.. I'd try it with what you have and see what happens. Good luck, hope it works out for you.
    snow bank
    The one I have doesnt work either. lol Hope I dont turn into a mallory superstore before this is done.
