air bleeds
Results 1 to 3 of 3
air bleeds
    Senior Member ohflat's Avatar
    Nov 2008
    Default air bleeds
    what condition while this cause if high speed air bleeds are plug
    It will cause a slight increase in fuel ratio. Meaning it will a bit richer when operating in that range of the carb.
    LaGrange GA
    If they hi speeds are corked up it should suck raw fuel out of the booster when the engine is running shouldn't it?
