Rocker Girdles ?
Results 1 to 14 of 59
Rocker Girdles ?
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    Default Rocker Girdles ?
    Can someone explain the use of a girdle (for the laymen) is it just for keeping alignment of the valvetrain? and IF it would be a good idea on a .638 lift solid flat tappet doing 6500rpm? (496 BBC) Ive got the Crane golds, just wondering if its added protection for them? or?
    Default Yes.....
    Yes, yes, and yes.....
    Ray
    LOUD BOATS SAVE LIVES
    Senior Member bp298's Avatar
    LHC
    are you asking about stud girdles???
    Peoria, AZ
    The purpose of the stud girdle (the girdle that sits over the rockers) is to strengthen the individual rocker studs by clamping all the studs together (by way of the extra tall poly locks) and therefore spreading the strength between all the studs. In doing so you are able to avoid stud breakage which is bound to happen with some of the aggressive cams out there these days. There is a chance you may break the poly lock (which I have seen) so it is not a perfect system, just better with it than without it.
    Paul
    The Right Coast/SE-PA
    I'm very happy with mine...and they were great to talk with too
    Added benefit > they do a great gob of deflecting oil from the valve cove breather
    Default Valve covers...
    It should be mentioned they won't fit under stock, or short aftermarket valve covers....
    Ray
    Peoria, AZ
    Ray
    Yep!
    Paul
    Kent, WA
    WEBSTER ,,,,, Scoggin Dickeys
    ptc
    ptc is offline
    Oct 2010
    Sacramento Area
    Paul
    Thanks Paul for that explanation, makes perfect sense now. Has stud breakage been a problem even when using ARP rocker stud replacements or mostly just stock configurations?
    Any recommendations on which girdle to use for my application?; BBC, 990 heads, ARP studs, Crane gold rockers 1.7 and already have the tall covers....
    Flat tappets don't generally have stiff enough springs to cause stud failures. Stud flex is there, but not to the degree that is with a roller. RPM and the required springs to allow the RPM on a roller deal is hard on the studs. Look at the broken rocker thread. If you generating enough load to break a rocker, your generating more than enough load to flex the stud to the point of fatigue.
    A flat tappet spinning 6500 doesn't require a stud girdle, but they never hurt either.
    ptc
    ptc is offline
    Oct 2010
    Sacramento Area
    Thanks Bob, I was reading that thread and is where I figured I would check this out.... The girdle seems like it is good insurance, are any types good to use or are some better than others??? Comp Cams (shown)m AFR, Howard, DART=$$$ ???
    Pink Taco Reagan's Avatar
    Santa Clarita, California, United States
    I added mine after busting a stud. Thanks to Jim at Cyclone Speed & Marine. My cam has 632 lift
    Redding, CA
    I haven't run anything with out stud girdles since the stock 427 in the purple flatty.
    On the Miller 454 with Brodix heads I have the Brodix girdle, on the Hydro with Chevy iron heads I bought the Webster setup.
    That Webster set is great
    Simple and works.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Kent, WA
