Spark plug question
Results 1 to 14 of 14
Spark plug question
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    Default Spark plug question
    New Brodix heads, never installed plugs yet. Today I tried installing 5 different Autolite 4054's in 5 of the holes, they each went in less than 1 turn and felt like they were going to cross thread, I only used my fingers to screw them in. I tried NGK 4554's and each screwed all the way in to the washer.
    Any ideas why this is happening?
    Quote Originally Posted by Franger View Post
    Seen it. Use the NGK. The is no reason to use another plug PERIOD!
    Senior Member Robby321's Avatar
    Jul 2011
    South Puget Sound, WA
    I had to check the thread...and ..well, one was taught today, plugs. As Autolite, have to be the worst plugs known to me, 55 years doing many motors. Still own many different..."but if NGK, does not fit, "you must acquit!"..(F OJ by the way too).NGK, or no way.....(ya nailed it dude!)..
    Senior Member Flyin-Bryan's Avatar
    Aug 2010
    Autolite spark plugs are now made in China.
    Redding, CA
    I've always ran NGK in my Brodix heads.
    Thats what they recommend, that's what I run.
    They had Autolites in them once, I didn't put them in, but I did take them out!
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Aug 2011
    Wasilla, Alaska
    Thanks guys, I had the Autolites from a previous motor and wanted to use them for start up only.....
    Peoria, AZ
    I have not been using autolites for very long, only 15 year and have not been disappointed. Now I bought a huge batch about 4 years ago and have only bought 5 or 6 individual sets since then, so they may have fallen off some. I tried NGK's once against the autolites in one of our cars and it did not like them as much. I am sure had we tried different heat ranges and stuff we could have made them work as well, but it wasn't worth our time. Maybe when I run out of plugs I will have to look into the NGK's again.
    Paul
    okie, lake Texoma
    Hhmmmm, I've ran both the ngk r5671a-8 and the autolite 3934 and have had no problem with either one. I also run the Bordix heads.
    H8-2-W8
    [email protected] first pass
    Senior Member lbhsbz's Avatar
    Long Beach
    X10
    I've seen plenty of plugs over the years with shitty/out of class threads. Call Brodix, ask the what thread they cut in the head, order a tap from McMaster (a good one) and run it through the hole hole to verify that it was machined right. Then go find some NGKs.
    Aug 2011
    Wasilla, Alaska
    X10
    Perhaps I didn't explain myself correctly in my first post. The NGK's went in perfect all the way to the washer using only my thumb and one finger. The Autolite's did not.
    The threads in the heads are fine, the threads on the Autolites are faulty, hope that clears it up.
    Aug 2011
    Wasilla, Alaska
    Paul
    Same here Paul, I used AC 44's or Autolites for general running around the lakes with no issues for 15+ years. I ran Champion BL13Y when I raced but that was 25 or so years ago lol
    I'm not a bit impressed with the Autolites nowadays tho .....
    Really? I am shocked. Find that really hard to believe. Tell me, how do you feel about Autolite's sister product FRAM???
    Ran Autolites religiously from high school days until sometime in the late 80's. Went to Champions but they were't the easiest plug to get, and I could never seem to get a handle on reading them. I knew NGKs from the bike racing days and notice more and more people were running them. Never looked at using another plug since.
    Jul 2011
    Jezz, here we go. I been doing many motors 55 years too. Am I incorrect that Autolite is what Fords ..(older?..but I'm Chevy guy)) came with? Means little to me anyway. Still have 6 bikes, dirt to road, too damn many boat motors, and the lawn care motors, as the cages. Factory made motors, are, to me, tuned for a specific plug. Fine with me..use what sugessted. But my old Shovelhead eats Champs..(far from stock though), and no prob NGK. My bagger likes Bosch. And my Merc OB's, like Champs. 350 (2) Chevys, A/C. As seems some plugs work fine, others not, is beyond me. Something so simple should be damn near...hell, I don't know. But as the first post stated, YEP, I have had ..(damn junk all made overseas now), many that had lousy threads, and simple tossed. And over the early years, boats, don't know how many heads I had to do, a idiot, brought to me, Heli-Coil. Some are so dumb, when it gets tight, after finger in and not seated.....grab a wrench. Anyway, this "thread" (pun intended!) ..can go on for ages, so what works for ya...well, any spark is better than no spark! And also, anytime I do new plugs now..(Machinst 21 years), run a known piece of good head threads, the plug first..maybe run chaser die on the plug, and a clean up tap, in the hole, where its going. Its all in the feel anyway. OH yeah! Back in the 70's, anyone remember those JC Whitney, "stop Oil Fouling plugs thingy? Simple a small thing, that ya screwed in the head, then the plug? Oiled mess in the cylinders, had to go through a hole, and then to the plug, and just the gas mixture, made it to the plug. Yeah, right. I have a 1965 6 cly Mustang, bought used..(just out on Nam then), and had them in. Going down Chitown Toll roads at 70, one blew out, and a nice dent in the hood too! Anyway, I can't resist this, as a old gearhead friend of mine here, getting up there in age, hard to walk, but a great guy, and a super wood "whittler", as does stuff like this too for fun also. Gets the used plugs from us. On Autolites?...my take too...a pic.......
    Aug 2011
    Wasilla, Alaska
    After the education I got from you Bob .... Fram oil filters are now in the same category as Autolites, "do not use". Autolites worked fine for me from the early 70's through the 80's until I sold my boat, never had one with bad threads and they lasted longer for everyday use than the Champions. I too discovered NGK's when I raced flat track in the mid 70's, just never tried them in my boat back then. Based on all the input I have read from guys like yourself I'm going to use them.... WTF, I CAN'T use the Autolites if I can't get em to screw into the heads lol
