Initial Base Timing
Results 1 to 10 of 10
Initial Base Timing
    Senior Member SBS933's Avatar
    Jun 2012
    Default Initial Base Timing
    Getting ready to put the motor back together, what should i set the base timing at ?
    Jun 2012
    Quote Originally Posted by sbs933 View Post
    getting ready to put the motor back together, what should i set the base timing at ?
    bbc n/a
    The Right Coast/SE-PA
    Base timing isn't really all that relevant as long as the engine doesn't buck on its self when started hot.
    You could be anywhere from 10-14 degrees of "base" idle timing > what counts is where the TOTAL timing is and when it's all in.
    example...My total at 2500 rpm and above is 35-degreese, when it idles down it's at 14 and STILL idles and 'hot-cranks' great.
    My engine will give a decent idle at 10 degrees too, below that and it's to chunky/lopey sounding...not clean and crisp.
    Depending what dizzy you're working with will allow for spring and stop bushings that will let you build the required idle, rate of advance and total.
    Jun 2012
    Thanks Hammer, I think 12 will be a good number. I'm gonna go with the old 32 deg. at 2500 and check it at 3000
    Is your distributor locked out? If so, initial timing is a moot point. Drop the distributor, put enough advance in it to make it start, set your total timing at 2500 and you're done. If your locked out, initial and total timing should be the same thing. If your still running springs, it will still be close.
    Jun 2012
    I'm running springs ICM. Last time i stabbed the dist. i set initial at T.D.C. and was told i should have set it ahead. Thats why i questioned it this time
    Jun 2012
    [QUOTE=HammerDown;1712608]Base timing isn't really all that relevant as long as the engine doesn't buck on its self when started hot.
    Depending what dizzy you're working with will allow for spring and stop bushings that will let you build the required idle, rate of advance and total.[/QUOTE Hammer last time iniital timing was set at TDC and yes it was a loppy idle.
    Like Icecreaman posted, set the total timing at what ever RPM it tops out at, and don't worry about the intial unless its below 10 degrees, which I doubt it will be if your total is 34-35.
    If I may suggest > don't go higher in total timing than needed.
    Meaning, if the engine doesn't make any more full throttle RPM at 32-35 degrees don't go thinking 38-40 must be better > cause it's not!
    Jun 2012
    Sounds good, Got it all down now and thanks for all the schooling guys. It's a lot easier when it makes sense.
