[Question] new top end
Results 1 to 2 of 2
new top end
    Sep 2012
    Default new top end
    I have a old 22ft Celeberty cuddy that im restoring it has a standard 260hp 350 with a alpha one and i wanting to do some top end work for a little more horsepower
    i do have have a set of 202 intake and 150 exhaust valve heads that have been milled for 10 to 1 copression that can use
    any sugetions on any othe conponents
    Tri-Cities, TN
    Marine application in an I/O I would not run over 9 to 1 with iron heads or 10 to 1 with Aluminum. You just never know when your going to run out of gas and the only thing available is 87 or 89.
    Bowl blend and some match porting to a good highrise dual plane should get you another 30 too 40HP.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
