Engine Build Question
Results 1 to 2 of 2
    Junior Member dans598's Avatar
    Sep 2011
    Brownsville PA
    Default Engine Build Question
    I want to build a n/a big cube engine for my 26' cat. I am thinking somewhere between 565-598 cubic inch Chevy.
    I want to run pump gas and would like to be in the 700-800hp range. I have a Dart tall deck block and a pair of 360 Pro Topline heads so far. I know some don't like these heads but I have had good luck with them on my other BBC. I am running a Bravo XZ upper with an Imco lower and 1.50 ratio. I would like some ideas on compression ratio and cam selection. Any help
    would be greatly appreciated. Thanks
    Close to the water...
    Quote Originally Posted by dans598 View Post
    I think a 1.35 gear will be needed, plus you would be pushing past the upper limit on that drive set up
