which starter you running?
Results 1 to 14 of 74
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    Default which starter you running?
    I have a blown alky bbc, looking at a new starter, have a 16V battery, just looked at summit online, thought about a tilton...but shit they are too high for me. Curious what u guys like.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Is your blower dragging again?
    Sell the 16v battery and buy a 12 volt Tilton. My answer Tilton is what we run.. Lots of starter grief before shelling out for it.
    QE 439 Twin Turbo
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    Yep, they sure are proud of their starters ....
    Led
    Led is offline
    Jul 2010
    blower isnt draggin, can roll it over by hand, starter is getting weak, and after a few more outings this one is getting replaced over the winter, geez $400 for a starter? hard to justify
    Senior Member bp298's Avatar
    LHC
    ran a tilton 15 years with no problems. it finally started to go away. now running a ron cook 2.6. had ron go through the tilton. it's now the spare. ron's starters work well, and the 2.6 will spin your engine... he is in parker az. 928-669-6411 just talked to him so i know the number's current...
    LHC
    Geez, only 400.00? What a whiner.
    LINK: Starter
    meziere is good stuff. and they're more in luv with their stuff than tilton is theirs...
    New Port Richey, FL
    Loose one race because of the starter and it's justified.
    QE 439 Twin Turbo
    Jan 2012
    lake Charles, Louisiana
    We run Ron's staters. I think the 2.6 would start a fueler. Never had a reason to return one.
    Led
    Led is offline
    Jul 2010
    TRUE!
    changing one in a pinch is a headache that I want to avoid almost at all costs, one bolt is on a tunnel, motor needs a little lift to get the bolt out, not a big deal, but dont want to be worrying about it at a race.
    Led
    Led is offline
    Jul 2010
    LINK: Starter
    I would like a cheese (preferably slices) with my wine, I have ran reman starter that worked great but time to play ball a little bit, but dang it $4-500, i am out, i might rig a pull start
    LHC
    TRUE!
    there's a little bit of solution to that problem. if it's sitting on the tunnel, can be solved. lifting the engine just enough to change starters isn't that big a deal. having it go south on sundays is not good. i've never lost a race due to a bad starter (knock knock on wood), but i've watched others get towed off the rope in eliminations because of it.
    ron's starters are not quite as costly as meziere or tilton. but they work. ron's an old comp hydro guy from the old days when comp hydro was a badass class.
    New Port Richey, FL
    TRUE!
    If you know a good machine shop you can machine the pad shorter where that bolt is so you can get to it. Or put a stud in that hole mill a relief slot so the starter can drop some and pull straight out.
    QE 439 Twin Turbo
