Oil in the intake?
Oil in the intake?
    Senior Member PuraVida Victory's Avatar
    Apr 2012
    Orange CA
    Default Oil in the intake?
    Was checking everything before we take the boat out tomorrow and saw this while i was cleaning the flame arrestor Click image for larger version.
    The hole throttle body and intake manifold has a coating of oil inside. Looks like its coming from the valve cover breather passage on the throttle body. Im thinking worn rings allowing to much blow by and forcing oil up the breather, but what else could cause this. Any opinions? Its a 98 Merc 7.4L MPI and Bravo 1.
    1998 Advantage 27 Victory BR
    1985 Commander 18' Closed Bow, 200HP Merc Outboard
    2012 Seadoo GTI130
    1993 Seadoo GTX (sold)
    1994 Seadoo GTX (sold)
    1995 19' Celebrity (sold)
    Morgan Hill
    Gonna go out on a limb and call it pretty normal. It is just in a spot where you can see it... Run it til she wont run no more....
    Does she burn a lot of oil? Betting not...
    JMHO
    GT
    Aug 2010
    put an oil seperator on the hose that goes from the valve cover to the intake. i put em on all my cars, keeps those pesky oil fumes out of your intake.
    Apr 2012
    Orange CA
    Im going to check the compression tomorrow and the pcv valve. Dont think its normal to have that much oil in there. It was almost a full drop on the bottom of the throttle blade when i first looked. It dosent burn much, maybe i top it off once before its time to change. It does have 340hrs.
    2012 Seadoo GTI130
