help with twin turbo head selection
Results 1 to 2 of 2
    Senior Member TTspectra20's Avatar
    Mar 2012
    South Bay of L.A. CA.
    Default help with twin turbo head selection
    Going to ditch the Iron Heads and Pick up a set of Brodix Race Rite Series Aluminum heads.
    Wondering if I should go with the 294cc or the 312cc intake runners? "will most likely be building a bigger motor once this one goes"
    Also I have 109cc closed chamber 291 heads on there now and the heads I'm getting have a choice of 115cc or 119cc chambers.
    What will the difference in compression be and will it be noticeable at all?
    Motor is a twin turbo 468
    Single boost referenced 850 with a lot of work done to it at the carb shop
    Tri-Cities, TN
    Go with the 312's if you are planning on going bigger CID in the future.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
