110 or 112 sunoco
Results 1 to 3 of 3
110 or 112 sunoco
    Senior Member tx-19's Avatar
    wittmann,az
    Default 110 or 112 sunoco
    Motor is 13.8 comp big block chevy with 18* heads.wondering if 110 is enough or should i stick with 112
    you might want to call their tech line:
    General phone: (215) 977-3000
    Fax: (215) 977-3409
    ( 112 )
    Sunoco Supreme is designed for compression ratios up to about 15:1 in small block V8s, and can tolerate higher compression ratios in smaller or more efficient combustion chambers. Supreme’s fast burn speed also makes it a popular choice for 2-stroke applications.
    ( 110 )
    Sunoco Standard is designed for compression ratios up to about 13:1 in conventional small block V8s, and can tolerate higher compression ratios in smaller or more efficient combustion chambers. It is also a good choice for mild nitrous, turbocharged, or supercharged applications.
    Senior Member bp298's Avatar
    LHC
    Quote Originally Posted by tx-19 View Post
    been running supreme for a lot of years. just swapped over to torco 112. mirror's supreme in ron/mon/sg. talked to several people that have been running it awhile now, they're very happy with it. cost was better, but that wasn't part of the criteria. customer service was miles better than what i had been dealing with.
