Blower Boost Vs. tune-up
Results 1 to 6 of 6
    Default Blower Boost Vs. tune-up
    If I change pulleys, what happens?
    I am currently running a 540 BBC, Dart Pro one heads, 9.4-1 Cr. with a Blower Shop 14-71 driven at 5% under on e85. According to the Blower Shop catalog I should be making about 9.5 lb. of boost. If I swap my current pulleys, the boost should go to about 12 lb. Would that a big change or just some change?
    My question is, should I expect to have to re-jet the Carbs. Also, should the idle speed change and what kind of hp change would be expected? I am currently making around 950 hp.
    If your tune up is good now, you shouldn't have to change anything. 2.5lbs of boost could add 50hp. The idle speed may go up a little.
    Senior Member racinjason65's Avatar
    May 2011
    Huntington Beach
    I have a 1471 on a 565 and when I swap pulleys I just change fuel and minor idle adjustment is all that's needed.
    I saw a thread that was written a couple of years ago related to this and in the first half of the threads there seemed some consensus that for each 1 lb. of boost there would be about 5-7% increase in power. Does anyone remember that thread?
    I only got through half of it, but that seemed a bit optimistic to me.
    Am I not remembering correctly?
    May 2011
    Huntington Beach
    5-7% is not realistic. On a 1,000 hp motor that would be 50-70 hp per pound of boost. I tried several pulley combos on the dyno, from 10% under and 6 lbs of boost to 16% over and 12.3 lbs of boost. We saw 25-30 hp per pound of boost.
    I am going to spend more time looking for that thread and read all of it, but the posts so far are more in line with what I would think might be correct.
    Thanks.
