Help with set up. 500hp M1 procharger
Results 1 to 2 of 2
    Guest
    Feb 2009
    Macomb -- Michigan
    Default Help with set up. 500hp M1 procharger
    looking for some expertise regarding set up.
    boat has a 500hp (aluminum heads) with an M1 procharger (intercooled) at 3-4psi boost. Fuel system consist of aeromotive a1000 fuel pump, 850 cfm holley carb
    i am concluding that this is a factory type set up from procharger (m1 kit)
    the pulleys are a 2.75 blower pulley and 7.625 crank pully
    looking to up my boost. boat runs 5100rpm with a 29p 4 blade and has a thunderbolt V ignition.
    would like to have 5-6 psi boost and possibly prop it down to keep off the rev limiter (not sure what it is set at on the 2003 hp 500s carb)
    i have researched that going down any more on the blower pulley will increase belt slippage and lose surface area...so thinking of staying at 2.75 and getting a larger crank pulley? any idea on where to get that from?
    or any other suggestions are greatly appreciated.
    thanks
    Call ATI and ask what pulleys they offer
    If your running a 6 groove you can always go to an 8 or 12
    Or bite the bullet and go go cog
    I would ask what's available for the M1
    #55
