Blower size
Results 1 to 13 of 13
Blower size
    SLOW MEMBER slowboy's Avatar
    Duluth, MN
    Default Blower size
    I am looking for recommendations of what size blower to put on my 408 small block.
    It currently has a stripped 671, on top of an intercooler. I am planning on getting rid of the intercooler, blower, and carbs and putting on something larger with fuel injection. Looking to make in excess of 1100hp on e-98.
    Thoughts?
    Kent, WA
    Whipple R980
    This should be fun!!!!
    Duluth, MN
    Whipple R980
    Could you recommend a larger one?
    Dec 2010
    Sapulpa ok
    A std. rotor 14 full open bottom should work fine. there's a looot of them out there cheap $1000 range.
    Duluth, MN
    Quote Originally Posted by piston in the wind View Post
    So put a big girl on it and spin it slow?
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by slowboy View Post
    yep or not spin that girl !!
    Arroyo Grande
    PSI C-rotor...and spin it about 125 over.......
    Jan 2011
    Mickleton, New Jersey
    Thoughts?
    small block thats a good idea?
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by EdonShano View Post
    We have a d rotor and are having rcd make a 95 center flange to go 220% at 8500 crank speed built for $385 would rather have a C at 125 any day !!!!!!!!!
    Duluth, MN
    I have been looking at the PSI stuff.
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    what ignition are you running? might thing about dizzy clearance?
    Duluth, MN
    Crank trigger.
