Timing cover
Results 1 to 14 of 25
Timing cover
    Sep 2012
    Default Timing cover
    Hi, Who makes a 1 piece timing cover that will clear a gear drive?
    Done heaps of internet searching and no one actually gives the dimensions on how far out they will clear?
    I got an RPC one not knowing and it hits the idler shafts need an extra 3mm space. Milodon have one but is there any others at all?, Thanks
    Aug 2010
    Placentia, CA
    Milodon's is a great product, have one on my 621 BBC engine.
    steveo143 AKA DiMarco 21 II
    Sep 2012
    Quote Originally Posted by ka0tyk View Post
    Yes it will but as stated looking for a 1 piece thanks
    Sep 2012
    Quote Originally Posted by steveo143 View Post
    Thanks, Thats what im leaning towards just seeing what else maybe out there.
    Do you have the polished or machine finish?
    Quote Originally Posted by Caribbean17 View Post
    His entire engine is polished,, aluminum block and heads, aluminum dry sump oil pan, fabricated intake..
    Sep 2012
    I have the cloyes dual idler and yet on the site it says designed for stock covers? Something not rite
    The RPC brand is an imported piece I believe. By "stock cover", Cloyes is referring to a GM tin cover.
    Placentia, CA
    Barry, would an Imco cover be made to work?
    It would be what I would try, but I didn't want to suggest it since it may also need to be machined to clear. I always use Milodon or Donovan gear drives with anything I build, so have not run into the clearance issue.
    Personally, I would try calling whoever made the gear drive being used to see what they suggest, instead of buying more parts that may or may not fit.
    Boy oh boy, ain't that going to be fun to keep clean.
    Apr 2010
    Rocklin, Calif.
    Good Ole Mexicalia Chrome right there...
    Sep 2012
    Ok cool, So the Std chev steel cover has more clearance than the cast alloy ones?
    This cover, and others like it are built to run a dual idler gear drive. It the reason for the dimples in the front.
    Link: Edelbrock T cover.
    I would have thought the mystique and fad of the dual idler would have been over by now.
    Some how a cheap Chinese gear drive is look at as being superior to a good USA made chain deal. Or at least "cooler"
