Small Block Chevy Compression?
Results 1 to 3 of 3
    Member Dano214's Avatar
    Aug 2012
    Lake Elsinore, Ca
    Default Small Block Chevy Compression?
    Question for you guys,
    Did a compression check on my stock small block today, this is a basic nothing fancy motor. All the cylinders are with in 5psi of each other and they were all between 115 and 120psi. Is this good? I was told the motor was low hours but i have no clue what it would run new. Thanks.
    Jan 2011
    Mickleton, New Jersey
    Quote Originally Posted by Dano214 View Post
    its OK I guess not enough info
    Aug 2012
    Lake Elsinore, Ca
    Im sorry, what other info should I include?
