350 Falls on it's face
Results 1 to 14 of 19
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default 350 Falls on it's face
    I have a buddy with a old Nova, has a SBC 350 in it, pretty much stock from what we can tell. The other day he said it started acting up where if he jumped on the throttle he claims it would "shake alot and go no where". He said if he rolled into it slowly it would get going. How today he's saying that if he mashes the gas it is just falling on it's face and almost dies. He said if he rolls into it it's fine though, says it takes about 3-5 seconds to roll into the throttle slow enough to get to WOT. I ran a quick test on his vacuum advance and verified it's at least holding vacuum and changing the advance. I'm wondering what else might be going on here. He's changing the rotor and cap right now.
    Any ideas?
    Dec 2009
    Northern Indiana
    Bad accelerater pump? Plugged fuel filter?
    New here Beer:30's Avatar
    Bakersfield, CA
    First guess - - accelerator pump, carburetor.
    The accelerator pump shoots additional/immediate fuel into the air stream to counter-act throttle increase. The venturies will eventually catch-up and provide the proper mixture (or close) but won't provide additional fuel until the airflow pulls it in. So, there has to be instant fuel to add to the instant air during throttle opening(s).
    Yes, could be ignition related or combo of both. However, if the car sits alot, accel pumps tend to dry out and eventually disintegrate. When this happens, there is no fuel to counter-act the additional air from opening the throttle and the engine falls on it's face (so to speak) until the venturies catch-up.
    San Clemente, Ca
    I had thought about the idea of it being the accelerator pump but wouldn't that just cause a hickup for a second? I though the point of the accel pump is to just bridge the gap were vacuum is lost when hitting the gas. Also, if it was the accel pump wouldn't the problem also exist when wapping the throttle in neutral?
    Either a fuel supply problem or a ignition issue.
    Bakersfield, CA
    If it's constant and never recovers, there are several things to check. The additional mention of fuel-filter is definintely another good place to look.
    I had one do something similar back in the day and it ended up being the LAST THING I replaced - - the coil. Also, a friend had an early Chevelle that developed a surge problem during cruise only. He kitted the carb (Rochester 2GC 2bbl), which didn't take it away. I loaned him a coil I had laying around and that fixed it.
    So, try a coil and see what happens. More is asked of it when requesting more engine RPM (accel) and it may not be up to the task. That's an easy swap.
    San Clemente, Ca
    He just called me and now it's doing it at idle. I had him verify the accel pumps are working and they are. Steady steam of fuel.
    Jan 2011
    Mickleton, New Jersey
    check the timing..full advance???
    what carb and how is the fuel pressure? Way to many reasons for this! Did this problem just start after a good running vehicle? how is the fuel filter? O.G.
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    sounds like carb to me, dumping too much fuel if u nail it, or not getting enough,
    Its Ignition.
    Tower Park Resort, Lodi, CA
    Any ideas?
    What brand carburetor and part#?
    Dual Plane or single plane manifold?
    HEI, points, or other?
    Does it idle perfect?
    How old is the fuel?
    Is the engine stock? If not, what mods?
    Have there been any recent changes or modifications?
    Has the car ever worked as it's supposed to since he's owned it?
    Lake Havasu az.
    X2...10 replies and nobody even knows what carb/dizzy.....And you sound exactly someone who intends to offer some valid advice
    Sheriff Joe Arpaio
    I may not have the answer, but once we stop shooting in the dark and shed some light on the subject... someone will. A lot of smart guys here.
