Foxwell/Straub Tech hyd roller 540 dyno results
Results 1 to 8 of 8
    Default Foxwell/Straub Tech hyd roller 540 dyno results
    Thought you guys might like to see dyno results from another Foxwell Motorsports/Straub Tech team effort. This is a hyd roller pump gas 540 going in a '68 Camaro.
    Details are:
    Dart block
    Scat crank and rods
    Mahle pistons and rings, 10.7:1
    AFR 315's prepped by FM
    Hyd roller by Straub Tech, Morel lifters
    Victor Jr/4150 ported by FM
    Crane Gold rockers, AFR stud girdle
    Smith Brothers pushrods.
    Customer had the engine assembled and dyno'd by his local shop in Glendale AZ. The heads, cam, lifters, rockers and intake came to me where I fully ported the intake, converted the heads to specific rate HR springs and Ti retainers, sized the guides correctly and then with the customer's cam and valve train parts, mocked up for proper rocker geometry and push rod length. Also had the heads milled to 119cc.
    Customer is very pleased.
    771.6 chp @ 6300, 717.4 clb-ft @ 5000. Made over 700 hp from 5200 on up.
    note: the dyno oil is XP4 15-50, and it never got over 160*. With a good 5-20 or 5-30 and some oil temp, there's another 15-20hp there.
    Peoria, AZ
    I don't know if I would trust that shop in AZ. You know about those AZ boys.LOL
    That is one heck of a build. Well done. And I know from personal experience that dyno does not give up big numbers.
    Paul
    Senior Member CNC BLOCKS's Avatar
    Sep 2009
    Great job guys.
    May 2012
    That things gona be a blast to drive did you see all that torque , little camaros gona need some meats to get goin any where
    Paul
    Thanks Paul. Ive come to learn a little more about Rick Waters...very well respected and successful engine buider as you probably already know.
    Great job guys.
    Thanks Carl.
    Quote Originally Posted by bowtiebro View Post
    LOL...ya think...
    Senior Member Tony Skagen's Avatar
    Senior Member Deweydaddy's Avatar
    DBN./DBN HTGS. Michigan
    Nice numbers for sure!!!!!! Most of my parts (kit) is from CStraub Ind. Pump gas hyd roller too.
