Fuel/Water separator ?
Results 1 to 7 of 7
    Sep 2011
    Los Angeles
    Default Fuel/Water separator ?
    I was trying to figure out where to mount the filter in the transom area. I was thinking of mounting it on the back of the seat, right next to the mechanical fuel pump. What do you think? Any pics?
    Jan 2011
    Mickleton, New Jersey
    Quote Originally Posted by larryfknrocks View Post
    sounds good to me
    waterloo
    It is mounted right on the block on my tractor. HAHA
    Good enough for an Oliver, good enough for your boat!
    Wags
    Redding, CA
    Mine is mounted off one of the transom adapter bolts on our Miller jet.
    Just high enough to clear the floor.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Sep 2011
    Los Angeles
    I was trying to mount mine there but it wasn't enough clearance. Imma get started on it today and see how it goes
    Senior Member N2GLOCK's Avatar
    Oct 2010
    My Rogers had it mounted directly onto the transom until I had the wood replaced. Now it's on the right stringer.
    Senior Member ontheNOS's Avatar
    Jan 2012
    Inland Empire
    Default hi
    I wouldn't mount it to the back of the seat, If its wood. When you replace the filter, it could tear up the wood turning. Just a thought. Wood does wrought.
